The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
22 members (55_2nd_Series, fixite7, D B Cooper, DennisM, BC59, BorderMechanical), 242 guests, and 3 robots.
Forums50
Topics122,204
Posts980,341
Members44,173
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1937 three speed jumps out of gear
#1087915 Wed Feb 25 2015 08:24 PM
Dusty Offline OP
I have been asked to fix a gearbox, It was hard to get into second and would jump out of that gear.
I've pulled it apart , and another 3 g/boxes and everything is worn.
I find it hard to tell what actually causes this defect as I have no new parts to measure.
For example , what end float should there be on the main shaft?
How thick for the 2nd gear thrust washer?
Who might have new syncro hub / gears etc?
What else might cause it to come out of gear?
Thanks for your thoughts.
Re: 1937 three speed jumps out of gear
Dusty #1088391 Sat Feb 28 2015 03:00 AM
Dusty Offline OP
Still struggling with a solution for this issue .
Surely someone has found a fix for this (now common) wear item.
Dusty #1088403 Sat Feb 28 2015 03:42 AM
All I can say is I had a '39 Master Deluxe car 50 years ago. Yes, half a century!
It had some kind of vacuum assist for shifting up-gear but the dang thing would help it shift out of gear to neutral when I backed off in high.
Not much help here.
1948 3/4-Ton 5-Window Flatbed Chevrolet [sandeace.com]
28 Years of Daily Driving but now on hiatus. With a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
Dusty #1088651 Sun Mar 01 2015 03:13 AM
When I found a place in Portland OR who had an older guy who knew all about the three speeds. He indicated that when the syncros are worn they will pop out of gear. He indicated the only fix is to replace the syncros. They don't make these anymore. He rebuilt mine because the difference between the parts and him doing the work was 100.00. He said he had hundreds of the transmissions.
Dusty #1092478 Fri Mar 20 2015 02:05 AM
I know that the 40-52 three speed will tend to wear the third gear teeth and that will cause the transmission to pop out of gear. The wear is the tapering of one end of the gear teeth slightly. The solution is to replace the part but that part is becoming rare since it often needs to be replaced. I imagine the parts for your trans will be even harder to find. This blog below has a good picture and explanation.
http://chev235guy.blogspot.com/search/label/Jumping%20out%20of%203rd%20gear
Moderated by  SWEET
