The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members (51sub, MY47, 5WINDOWJOHN, mick53, latroca52, AlpineBolt, 1 invisible), 119 guests, and 3 robots.
Forums50
Topics119,452
Posts956,402
Members43,405
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 3 of 5 1 2 3 4 5
Re: 1941 Chevy 1/2 Ton (AK) Truck Project
41-327 #1080236 Mon Jan 19 2015 08:50 PM
41-327 Offline OP
Time for an update...
We finished the engine revisions and got it back in. It sounds totally different that it did but it does run better than before. Due to weather and other factors, we have not been able to drive it much since getting it back together.
A pic of what the engine looks like now. We had to loose the 'vintage Chevrolet script' valve covers due to the roller rockers but it still looks good.
http://i1296.photobucket.com/albums/ag13/catfish_fry/20141012_150452_zps68cf8546.jpg
We are now doing the daunting task of body work (not my favorite thing...).
Working on the fenders and front end at this time. Rear fenders are next then to the doors.
http://i1296.photobucket.com/albums/ag13/catfish_fry/20150106_215018_zps2f6e385e.jpg
Does anyone have an idea if there is a template for the shape if the top portion of the lower grill??? The top of this one is ~1" behind the lower part of the upper grill. We are working on matching them up...
http://i1296.photobucket.com/albums/ag13/catfish_fry/20150106_215004_zps3c469d63.jpg
Currently having the windshield frame blues... The one we have appears to be too rusted to salvage and getting it apart in the center is not working out too well either...
We will be tearing it down in the next month or so to get everything sand blasted. Then it will be time for some primer and filler...
41-327 #1080555 Wed Jan 21 2015 04:42 AM
Boltergeist
You've come a long way. Your hard work is looking good. Way to go.
Pictures in my Photobucket
52 Chevy Panel
41-327 #1083433 Tue Feb 03 2015 08:49 PM
41-327 Offline OP
41-327 #1083485 Wed Feb 04 2015 02:27 AM
Looking good, nice job!
41-327 #1083567 Wed Feb 04 2015 01:10 PM
Lookin' Good!!
1946 Chevy small block truck
1941 Chevy 3/4-Ton
"Ole Rusty"
More pix on Photobucket
41-327 #1083599 Wed Feb 04 2015 06:27 PM
I like it ! Looks like a lot of the hard work is behind you.
41-327 #1085024 Wed Feb 11 2015 03:16 PM
V
VEW Offline
Nice work Thad.
What rear are you using? Also, what is your steering column from? Did you need to do any modifications to fit it in, like shortening it? I have one from a '93 Blazer I'm thinking about using. I am also using a 700r4, so would be just fine with the column shift.
Thanks, and once again, really nice work!
Victor
41 3/4 Ton Pick Up (in process)
55 Grumman Kurbside (Doughboy) 235/3 on tree w/ OD
57 3100
58 C4400 Viking (Thor)
59 C4500 Short Bus (Magic Bus)
59 G3800 1 Ton Dually (Chief)
41-327 #1085052 Wed Feb 11 2015 06:05 PM
41-327 Offline OP
The steering column is from an 85 chevy van, the rear end and springs are from a 1993 Ford Explorer. We added a 1" adapter to each side to get the width we needed due to wide rear tires (255 70R 15).
41-327 #1127813 Sun Oct 04 2015 12:54 AM
41-327 Offline OP
Daunting body work task....
Well it has been 9 months of cut, patch, re-patch, weld, ect and it is now almost ready for the epoxy primer... Yea.
No pics to share this time but soon.
Looking at gaskets, seals, weather stripping, ect.
I am looking to get a few things from Steele Rubber Products and the rest from Jim Carter... Are there better sources?
41-327 #1127858 Sun Oct 04 2015 04:41 AM
Boltergeist
....are there better resources?
You've dealt with two of the best but there are others. Sometimes it just depends on what the item is your looking for.
Congrats on your hard work. It'll surely be worth it and will last a long time.
52 Chevy Panel
Moderated by  J Lucas
