The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (66flea, 55shaker, Chiana River, Donf, 7045george, 2 invisible), 136 guests, and 2 robots.
Forums60
Topics124,936
Posts1,008,317
Members45,097
Most Online1,229
Jan 21st, 2020
Image Posting Policy
265 v8 clutch size
#1072906 Fri Dec 12 2014 03:53 AM
TPR57C Offline OP
hi all I am seeking clutch size for a 265v8 all the books from truckshop LMC don't have size for 265 v8 merry xmas to all
Re: 265 v8 clutch size
TPR57C #1072908 Fri Dec 12 2014 03:59 AM
According to the Shop Manual, it is 10" for 1/2 through 1 1/2 ton for both 6 and V8.
Bill Burmeister
TPR57C #1073044 Fri Dec 12 2014 10:37 PM
There were lots of options on clutch sizes. You have to measure it to be sure.
1972 Chevy c10 Cheyenne Super
TPR57C #1073105 Sat Dec 13 2014 03:25 AM
Interesting read, might give you some idea of which clutch you can use:
http://www.hemmings.com/hmn/stories/2011/10/01/hmn_feature29.html
DG
TPR57C #1073160 Sat Dec 13 2014 05:47 PM
I recently replaced a clutch on what appears to be an original 55-2 with a V-8. It was an 11" unit. I wouldn't buy any parts until I removed it to be sure.
Fred
TPR57C #1074026 Thu Dec 18 2014 06:00 PM
I also have a 265 and it depends if it is a truck or a car motor the flywheel is different sizes found out mine is out of a Belair and it is smaller then a truck
jeffw #1074075 Thu Dec 18 2014 08:51 PM
TPR57C
I have had a few '57 3100's with 265/4 speeds, all are org and all had 11" clutchs. For what it's worth.
delky dave in WYO
1957, 3100, v8
1990 Suburban
delky #1080756 Thu Jan 22 2015 11:36 AM
TPR57C Offline OP
Finally pulled clutch out 11 inch 10 spline worn out that much springs on clutch plate were rubbing on flywheel bolts
Moderated by  SWEET
