The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (dands, EdPruss, 3B, Achipmunk, Brad Allen, DaveMcK38, 1 invisible), 122 guests, and 3 robots.
Forums50
Topics119,477
Posts956,645
Members43,409
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 3 of 5 1 2 3 4 5
Re: Tired Of Double Clutching???????
marvin ribbich #1162955 Fri Apr 29 2016 02:13 PM
btt
marvin ribbich #1186599 Thu Oct 13 2016 02:13 PM
Has anyone tried to make and install this adapter on there truck???
Marv.
marvin ribbich #1186605 Thu Oct 13 2016 02:57 PM
I considered doing it. My son is putting a 1954 235 into his 1946 2 ton truck. I wanted to keep everything from the 46 motor kept together as I did not want to mix and match parts between the 54 and the 46.
Being the 54 came with the clutch housing I thought about having the adapter plate you designed made and used. But I did not think I would have enough time to have one made. Being my son uses his truck for his catering business I did not want to delay getting his truck back on the road.
Turns out the machine shop took so long to do the rebuild I could of had a truck load of adapters made.
So I am using the 46 clutch housing on the 54 engine.
I am going to put the 54 clutch housing on the 46 engine so I can mount the 46 engine on a 1945 1/2 ton rolling chassis. As soon as I can find a front motor mount. Jeffrey
Your adapter plate is why Stovebolt is a great place. I learn about great things that I may not use but is great to know because one never knows when and what he will come across in the future. Jeffrey
marvin ribbich #1186614 Thu Oct 13 2016 03:56 PM
3B Online
Hy 32vld, just to let you know the 1954 and 55A series trucks use an angled mount at the bellhousing to frame connection, the earlier trucks use a flat mount, so the later bellhousing will not mount into the earlier chassis, hope that helps.
marvin ribbich #1196422 Thu Dec 22 2016 11:58 AM
btt
marvin ribbich #1203860 Sat Feb 11 2017 03:39 PM
btt
marvin ribbich #1211289 Sun Apr 02 2017 12:35 PM
btt
marvin ribbich #1246983 Fri Dec 15 2017 01:24 PM
btt
marvin ribbich #1246992 Fri Dec 15 2017 03:41 PM
3B Online
Hy marvin ribbich, all the links to pictures of your excellent adapter are dead, if you want people to be able to make the adapter for themselves you should repost your pictures.
marvin ribbich #1247055 Sat Dec 16 2017 02:04 AM
3B
Thanks!!! for letting me know, if any one has a interest they can call or email me, I can send pictures. 1-262-392-2989 or mribbich@wi.rr.com
Moderated by  SWEET
