The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 registered members (51sub, Cosmo, carryall jerry, 5 Window 9434, 2 invisible), 311 guests, and 2 spiders.
Forums47
Topics116,116
Posts923,317
Members42,345
Most Online940
Apr 5th, 2017
Image Posting Policy
mystery differential carrier in 1955 3800 dually - casting numbers?? #1040664 Mon Jul 07 2014 06:41 PM
X
x75 Offline OP
Thanks to anyone who can help!
I'm replacing worn out bearings on the rear end on a 55 commercial truck, and the carrier (or maybe the whole axle assembly) does not appear to be original. I found axle bearings OK, but I'm stumped by the carrier.
Casting # 3766686
underneath that casting number is a line with:
slotted screw-head-looking bump pointing at 1 o'clock
the numbers '137'
slotted screw-head-looking bump pointing at 3 o'clock
wagon wheel
the letter 'D'
underneath all that is an 'X'
elsewhere is stamped 'MH608' and a crooked 'D' and another crooked 'H'
I'm just trying to help my local NAPA dude get me the correct bearing kit.
Maybe an early 60s 3/4 ton setup?
Re: mystery differential carrier in 1955 3800 dually - casting numbers?? [Re: x75] #1040683 Mon Jul 07 2014 07:43 PM
Grigg Offline
This is where a picture is worth near 1,000 words.
Do you have a picture you can link to?
1952 Chevrolet 3800 pickup
---All pictures---
Re: mystery differential carrier in 1955 3800 dually - casting numbers?? [Re: Grigg] #1040938 Tue Jul 08 2014 03:43 PM
X
x75 Offline OP
sorry, don't know how to do that.
it's a 14 bolt differential with that casting number. NAPA dude needs year/model of the casting # to order bearing kit.
I'm guessing early 60s 3/4 ton and might just try that.
Re: mystery differential carrier in 1955 3800 dually - casting numbers?? [Re: x75] #1040976 Tue Jul 08 2014 05:51 PM
Grigg Offline
If all else fails, with the old bearings in hand you should be able to read the numbers and or measure them to match up the new bearings.
---All pictures---
Moderated by  Grigg
Powered by UBB.threads™ PHP Forum Software 7.7.3
