The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Positive thinking ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (DaveV, 78buckshot, Bwienke, Bill Marlow, DES57, 1 invisible), 86 guests, and 2 robots.
Forums60
Topics127,472
Posts1,031,732
Members45,787
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
motor oil for a 235
#1037094 Sun Jun 22 2014 11:29 AM
CJSTP Offline OP
My 51 3100 has a rebuilt 59 235 in it. The motor is clean inside (no built up crud).When I got it I drained the crankcase and put in off the shelf brand name 10-30w oil. Now that I have a few hours on it and am installing an oil filter I want to change the oil.I plan on changing it often.
My question is,is there any reason not to use good quality 10-30w motor oil in my motor? If there is, what would you recommend?
Growing up I was taught to use non-detergent 30w oil in an old motor but this motor has been rebuilt and most likely cleaned so I'm assuming that basic motor oil is proper.
Thanks---Jack
Re: motor oil for a 235
CJSTP #1037098 Sun Jun 22 2014 01:00 PM
Jack,
You might have opened a can of worms.
In the late 60s, I was also told to use non-detergent oil in a 216 and a high-pressure 235. However, by the time the high-pressure 235s were introduced (1953/54), GM was recommending detergent multi-grade oil.
GM was also recommending detergent oils in earlier years, for hard-working engines.
Your 10-30w (10-30, 10W-30) oil is OK.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
CJSTP #1037127 Sun Jun 22 2014 03:27 PM
Agree, A good brand of 10/30 will be excellent in that engine. When you get that oil filter on it you won't be able to see the oil on the stick as it will be so clean.
1972 Chevy c10 Cheyenne Super
CJSTP #1038566 Sun Jun 29 2014 12:13 PM
Detergent oil was available in the early 40's. In 1942 the US Military had almost universally switched to it and requiring filters on almost all motor vehicle engines.
A good 20W or 30W oil is all you need.
I would run a 20W oil over a 30W. Your main concern is engine start up and cold viscosity.
CJSTP #1038570 Sun Jun 29 2014 12:50 PM
Quote
My question is, is there any reason not to use good quality 10-30w motor oil in my motor?
There is no reason not to use a good quality 10-30w oil in your motor (or, any other modern multi-grade oil).
Tim
CJSTP #1038614 Sun Jun 29 2014 03:58 PM
"20W" is not 20 weight...
CJSTP #1038770 Mon Jun 30 2014 02:35 AM
I ran 10W-30 in my rebuilt high oil pressure 235 with hydraulic lifters. I had one lifter that would clack until it reached operating temperature. I switched to 5W-30 and the lifter started to act right at all times thereafter.
panic #1039052 Tue Jul 01 2014 01:56 AM
But that's how it appears in the manual
You always want to run the lightest weight oil you can because the oil does not reach its listed viscosity when cold. 30 weight (or ever 30W) oil much more viscous 'cold' then when at operating temp... and the few minutes its takes to get to operating temp is when all the wear takes place.
You will see lower gauge pressure with the lower viscosity oil on worn engines and using 30 weight or even 40 weight oil is not a fix, just a crutch to make the oil gauge 'look right'.
So it is 'wrong' to use 30 weight oil? No. Given the choice 20W or even straight 20 weight oil is preferred.
CJSTP #1039059 Tue Jul 01 2014 02:10 AM
And when we ran straight weight oils, we changed them summer and winter. Now we use multigrades, and only change them when needed. I'd give it a go with the 10W30. A light 20W may thin out too much in hot weather.
panic #1039060 Tue Jul 01 2014 02:16 AM
I"ll bite
Winter? Or Weather?
ohwell
Page 1 of 2 1 2
Moderated by  Woogeroo
