The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 registered members (68ironhead, 48loadMT, Greg_H, Greg Brown, aduncan, 1 invisible), 300 guests, and 3 spiders.
Forums47
Topics115,665
Posts919,164
Members42,311
Most Online940
Apr 5th, 2017
Image Posting Policy
New harness, non stock distributor won't start #1031903 Thu May 29 2014 01:39 AM
Shank Offline OP
55 Chevy 2nd series, 235, new wiring harness, starter (stomp), coil, etc. Has a mallory distributor instead of stock. Engine turns over but no voltage to the pick up coil. Do I need to wire different from stock configuration since its not a stock distributor? Would like to fire it up for the first time. Appreciate any advice.
Mark
Task Force 55
Re: New harness, non stock distributor won't start [Re: Shank] #1031920 Thu May 29 2014 02:43 AM
Flxible Offline
shouldn't be any different, although I don't know if you need the ignition resistor, I'd start tracking wires and make sure you have everything in the right place and the ignition switch is doing what it should
Re: New harness, non stock distributor won't start [Re: Shank] #1032145 Fri May 30 2014 02:17 AM
Shank Offline OP
OK Bill Thanks. I'll start there
Task Force 55
Re: New harness, non stock distributor won't start [Re: Shank] #1032183 Fri May 30 2014 03:57 AM
Roy Rodgers Offline
What style Mallory distributor are you using?
Re: New harness, non stock distributor won't start [Re: Shank] #1032597 Sun Jun 01 2014 03:56 AM
Shank Offline OP
Turns out the wiring harness is incorrect. After reviewing the service manual, the 3 prong connection to the ignition switch had the wrong colored wires going to the wrong posts. So made some jumper cables to make the correct connections and then got power to the ballast resistor and the the coil. Then she fired right up. Appreciate it gents.
Mark
Task Force 55
Re: New harness, non stock distributor won't start [Re: Shank] #1032599 Sun Jun 01 2014 04:17 AM
LONGBOX55 Offline
Just out of curiosity, what wire harness manufacturer was it? I had one from Y-n-Z, the ignition switch connector on it had the exact same problem.
Bill Burmeister
Moderated by  Rusty Rod
Powered by UBB.threads™ PHP Forum Software 7.7.3
