Remember
The old Bulletin Board?
click to enter
The old Bulletin Board has been removed from the server. And with recent "spring" cleaning, we are removing links back to it. The BB is still out in cyber space (to some extent) thanks to The Wayback Machine.
Oh Lord, I just gotta find it....
14 members (EchoBravoSierra, 55shaker, 68ironhead, 3B, 59 fleet, DougH6100, 1 invisible),
88
robots. |
Key:
Admin,
Mod
Forums59
Topics128,110
Posts1,037,373
Members45,936
Most Online1,229 Jan 21st, 2020
OP
Is this casting number a Saginaw 4 speed? The side of tranny casting number is GM 3781980. It has a granny gear and wondering if there's a swap to eliminate granny and get better gearing for in town and highway use. It appears to be the original transmission. Thanks.
you have the standard SM420 4 speed, usually folks just ignore 1st and use it as a 3 speed .... your choice is go with the original standard 3 speed, no granny, but still 1:1 high, or find an original style OD 3 speed, or switch to a modern OD trans .... or change the rear gears to the [sometimes] available 3.38 ratio
