We are still asking:
What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures and No BOTS.
So ...
What did you get done on your Bolt today????
Oh Lord, I just gotta find it....
Forums60
Topics127,490
Posts1,031,879
Members45,791
Most Online1,229 Jan 21st, 2020
 1959 3200 tranny type
OP
Is this casting number a Saginaw 4 speed? The side of tranny casting number is GM 3781980. It has a granny gear and wondering if there's a swap to eliminate granny and get better gearing for in town and highway use. It appears to be the original transmission. Thanks.
 Re: 1959 3200 tranny type
you have the standard SM420 4 speed, usually folks just ignore 1st and use it as a 3 speed .... your choice is go with the original standard 3 speed, no granny, but still 1:1 high, or find an original style OD 3 speed, or switch to a modern OD trans .... or change the rear gears to the [sometimes] available 3.38 ratio
