The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members (Eureka Jim, Eisenhart1992, HandyAndy, Ed Blouch, bwilliams, 66flea), 129 guests, and 3 robots.
Forums50
Topics118,977
Posts952,351
Members43,300
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: 1954 chevy 3100 OD trans??
Deve #1025862 Sat May 03 2014 03:58 AM
True,
Check out what this guy says.
I once owned a 1948 Willys jeep.
The guy I bought it from, put a Chevy 283 V8 in it.
The original 4 cylinder Flathead horse power rear springs just could not handle the V8 torque.
The pinion bearings prematurely wore out because the axle would whip so bad.
DeanThe54Chevy #1025863 Sat May 03 2014 04:02 AM
If you get the '55 first springs with the rear end the problem is solved.
My TRUCKS website
DeanThe54Chevy #1025866 Sat May 03 2014 04:08 AM
ace skiver
DeanThe54Chevy,
"I want to keep the truck stock with the 3-column shifter, but make it better for cruising highways."
I can cruise highways all day in my 1954 Suburban at 65 mph with the 3.55 Ring & Pinion conversion (enclosed drive shaft) and 31.5" diameter radial truck tires (about 2500 RPM). This has worked fine with the original 3-speed and 4-speed.
If I wanted an OD, I'd go with Tommy's recommendation - SM319 and suitable rear end. I think that is what Cletis has, and one of my neighbor's has that in his 1953 1/2 ton panel. It is is nice set-up.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE [1954advance-design.com] - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
tclederman #1025876 Sat May 03 2014 04:33 AM
DeanThe54Chevy,
I have the Mr. Magoo syndrome.
jorb #1028644 Wed May 14 2014 09:41 PM
My apologies. Lol, not a trick question. But yes, 1954 1/2 ton
Psalm 32:8
Page 2 of 2 1 2
Moderated by  SWEET
