The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (AwDang, 59 fleet, 81tta, Jon G, Denny Graham, 2 invisible), 262 guests, and 4 robots.
Forums50
Topics120,082
Posts961,740
Members43,550
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
52-59 Dual Wheel front disk brake
#1024600 Sun Apr 27 2014 06:47 PM
OlBlue Offline OP
This is on a '56 GMC 1-Ton.
'56 1-ton disk brake conversion
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
Re: 52-59 Dual Wheel front disk brake
OlBlue #1024737 Mon Apr 28 2014 03:38 AM
Interesting I wondered if that couldn't be done the other day. Less wheel rub issue maybe. I wonder what brakes were used.
Just here for the free beer.
1953 1-Ton Dump Truck
1954 Teenage Hot Rod
OlBlue #1024899 Mon Apr 28 2014 11:09 PM
OlBlue Offline OP
Chevy 3/4 ton K series (4x4) front brakes
'71-'86 3/4 ton K series rotors
'71-'78 3/4 ton K series calipers & brake lines
Later calipers went to metric size hose connection.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
OlBlue #1024973 Tue Apr 29 2014 04:50 AM
Where did you get the bolt spacers and rotor spacers? Why did you not just go with larger bolts through the rotor and drill the hub? Is the center ring even necessary?
duesenberg1 #1025062 Tue Apr 29 2014 04:48 PM
OlBlue Offline OP
A local machine shop made the parts for me.
Larger bolts with larger nuts would interfere with the outer diameter of hub casting just inboard of the brake flange.
The ring keeps the rotor concentric with the hub.
I checked the clearance between the rotor bolts in the original application and the the rotor bolt hole diameter and found it pretty loose. It looked like the factory used the center bore to keep it centered so I just did the same.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
OlBlue #1025080 Tue Apr 29 2014 05:52 PM
What is the thickness of the steel plate?
OlBlue #1025098 Tue Apr 29 2014 06:50 PM
What size bolts for rotor?
duesenberg1 #1025166 Tue Apr 29 2014 11:33 PM
OlBlue Offline OP
The plate is 1/2 cold rolled steel. The mounting tab on the bottom is offset 1/2" using a piece of 1/2" square stock welded between the tab and the main plate.
When I had the plate cut, I made the tab 1/2" longer so that it would overlap the main plate. I bolted the main plate to a spindle and the tab where it went and then placed the piece of square stock in between and tack welded it. There are 4 separate beads of weld holding the tab on so I don't think it will go anywhere.
The bolts holding the rotor on are the same thread size as the studs that held the drum on but longer to fit the rotor.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
OlBlue #1026165 Sun May 04 2014 07:55 PM
John, Have you considered selling the unique parts that you have designed. I would be interested in purchasing a "adapter" parts kit. My 55 1 Ton would be a perfect candidate for upgrading.
Thanks in advance. Howie near Calgary
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine
4 1966 Plymouth VIP 5.7 GenIII Hemi
5 1966 Imperial Crown Coupe 440 engine
OlBlue #1027358 Fri May 09 2014 02:55 PM
Do you have any dimsioned drawings for the mounting plates. CAD drawings etc.
Page 1 of 2 1 2
Moderated by  Grigg
