The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 members (55shaker, 3hansens, D$TROYER, '37 barn find, 48bigtrucks, DennisM, 2 invisible), 114 guests, and 5 robots.
Forums60
Topics126,065
Posts1,018,869
Members45,419
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: steering box grease
56srw #992065 Thu Dec 12 2013 02:27 AM
Gas Pumper
Ima go down to JD and ask for Corn Head. I sure hope I don't get something I didn't expect, but sounds like the best solution. wink
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
56srw #992293 Fri Dec 13 2013 05:22 AM
How many tubes do you need to fill the box?
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
56srw #992309 Fri Dec 13 2013 01:09 PM
56srw #992414 Sat Dec 14 2013 12:08 AM
When I filled my steering box with cornhead grease, it took a few times, filling to the top each time. The grease takes a while to flow down into the nooks and crannies and work its way into the balls and ball nut. I checked it a day or so apart, and I think I added grease 3 times. I have not used up the first tube yet. I think I'll go out and check it again!
56srw #1022985 Sun Apr 20 2014 03:54 AM
56srw Offline OP
finally pumped a whole tube of grease in steering box, feels like power steering now, but bump steer all over the place
56srw #1023074 Sun Apr 20 2014 05:09 PM
My truck had lots of issues with the steering when I got it first driving. Bad bump steer and even death wobble..... Steering box out of adjustment, no grease in steering box, worn loose wheel bearings, worn out tierod ends, excessive toe out, loose steering arm joint, and 10in wide rims on the front, and to top it off a tiny aftermarket steering wheel. What a disaster! When I had fixed all these issues, and then fitted a steering stabilizer, now my truck drives and steers great.
56srw #1023096 Sun Apr 20 2014 06:40 PM
FYI, Bump steer is a suspension / steering geometry problem. If interested Google bump steer and you can see diagrams.
Page 2 of 2 1 2
Moderated by  SWEET
