The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (billinwisconsin, 55 SHAKER, 66flea, 5 Window 9434, glenns towing, 2 invisible), 179 guests, and 3 robots.
Forums58
Topics122,583
Posts988,945
Members44,491
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Correct balancer and flywheel good wrench replacement
#1016152 Sun Mar 23 2014 02:10 AM
blu1964 Offline OP
Replacing a 327 with a new goodwrench 350.I know they changed the flywheel to a balanced one somewhere a long the way,maybe mid 70s.What is the correct ones for the goodwrench?
Re: Correct balancer and flywheel good wrench replacement
blu1964 #1016208 Sun Mar 23 2014 01:09 PM
Small block chevy engines with the exception of a 400 are internally balanced. If you order a replacement engine to match what you are removing the original parts should be the same.
Tommy
59 apache 1/2t
261 short stepside
blu1964 #1016211 Sun Mar 23 2014 01:23 PM
In 1987 the 350's changed to a one piece rear main seal. The crankshaft is different and uses a different flywheel and balancer. Do you know what rear seal type your motor uses?
don stocker #1016309 Sun Mar 23 2014 07:07 PM
blu1964 Offline OP
Yes it has the 2 piece rear seal.I am replacing the balancer because of age but planned on using my flywheel.I know the 400 is externally,but the parts stores show a balanced flywheel for a 350.
blu1964 #1016438 Mon Mar 24 2014 04:35 AM
If both engines use a 2 pc rear seal then they can interchange. As stated, once the SBC began using the one pc rear seal, then those crankshafts also require a flywheel/flexplate with a counterweight on them to be balanced, and will not interchange with an engine that is a 2 pc rear seal. The "balanced" terminology from the parts store could be hinting that the app he lists one for is the later counterweighted one.
We cannot solve our problems today using the same thinking we used when we created them!
Albert Einstein
12 Port #1016480 Mon Mar 24 2014 01:03 PM
blu1964 Offline OP
Thanks that makes it tie together.Kinda been out of this game a few years.I used to know most of the interchangeability of bowtie parts,but age, time,etc takes place of that stuff.
Moderated by  Woogeroo
