Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
6 members (baldeagle, 55PizzaTruck, BC59, Rusty Shackleford, Hotrod Lincoln, 1 invisible), 57 guests, and 3 robots.
The Zone
Forums65
Topics123,445
Posts999,563
Members47,279
Most Online1,229
Jan 21st, 2020
#1014181 Fri Mar 14 2014 05:54 PM
Gents,
I am planning on attending homecoming this year for atleast a day. Can someone give me the address or directions? Also, i may have a potential issue that i need the ODSS's brain power (smarts) to take care of. I took the bracket off of my truck that holds the rear leaf spring. the hingespring doesn't fit. I am trying to get it fixed before, but wondering if anyone can help... i was told i need an 11/16th tap to clean up the threads.
Chris
ndkid275 #1014195 Fri Mar 14 2014 06:48 PM
Pictures? I have a lot of taps but not sure what you need or are trying to do? 11/16" is not a very common tap/thread size, what is the pitch you need?
1948 Chevrolet 6400 [stovebolt.com] - Detroit Diesel 4-53T - Roadranger 10 speed overdrive - 4 wheel disc brakes
1952 Chevrolet 3800 pickup [stovebolt.com]
---All pictures [picasaweb.google.com]---
ndkid275 #1014221 Fri Mar 14 2014 09:20 PM
Grigg,
i found a place called "the restoration shop" down in stafford. They are going to call me with the pitch and see if they can do it. Just curious if anyone has heard of Ralph down there. "www.therestorationshoponline.com" Going to talk to them about doing a few projects for me such as rebuilding my 216 and street rodding it a little but keeping it like it would have been in the 50s.
ndkid275 #1014276 Sat Mar 15 2014 03:04 AM
Unrepentant VW Lover
Chris,
Homecoming, and the ODSS Braintrust (such as it is ...), will be at:
41370 Friendship Ct,
Mechanicsville, MD 20659
Slap that into your GPS and it should zorch you right here.
Looking forward to meeting you. Bring your project and we'll help!
"If there are no dogs in Heaven, then when I die I want to go where they went."
Will Rogers
1927 Chevrolet Capitol 1-Ton Express -- A work in progress
In Project Journals
1949 Chevrolet 3804
In Gallery Forum
1973 IH 1310 Dump
2014 Ford E-350 4x4 (Quigley)
In Daily Driver Gallery
ndkid275 #1014284 Sat Mar 15 2014 03:31 AM
not sure if i have a trailer to haul my whole project! :-)
I took the part into a machine shop and they are supposed to call me this weekend to tell me if they can do it.
Thanks for the address.... i am guessing that i will be there all day saturday. I will be ready to learn from all of you and meet you all.
Chris
ndkid275 #1014289 Sat Mar 15 2014 03:41 AM
I just checked and don't think I have any 11/16 taps.
ndkid275 #1014290 Sat Mar 15 2014 03:43 AM
Chris,
We all look forward to meeting you ...
I'm not sure what you'll learn from the rest of us ...
smile
Will Rogers
In Project Journals
1949 Chevrolet 3804
In Gallery Forum
1973 IH 1310 Dump
ndkid275 #1014673 Sun Mar 16 2014 05:41 PM
other then learning how to drink.... I can learn a ton since i am new at this rebuilding stuff compaired to 99% of stovebolt. I enjoy learning from you "seasoned" guys that have learned little tricks and have more knowledge then I ever will!
ndkid275 #1014975 Mon Mar 17 2014 09:56 PM
Chris,
Did you get that bolt problem worked out? Was that the same bolt I helped you with or the other side? I am more than happy to take a look at it for you if you want.
Russell
ndkid275 #1014986 Mon Mar 17 2014 10:53 PM
I have it taken care of Russ. I took it into the shop and they ordered the correct Tap for it since the restoration shop didn't have it! Should be done soon and then i will have a rolling chasis until i take the front axle off for the 4" drop on it.
We need to get together sometime. I would love to learn from you.. by the way, are you going to homecoming russell?
Moderated by  Bill Marlow, SWEET
