The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (DaveV, 68ironhead, jameschevypu50, NorCal52Suburban, 87GN, 2 invisible), 105 guests, and 4 robots.
Forums59
Topics128,597
Posts1,041,768
Members46,055
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1012479 Fri Mar 07 2014 07:10 PM
After having had my 235 6-cylinder rebuilt in 1987 I am in the process of the final reassembly which includes mounting the starter, generator, coil, and other similar items. Mounting bolts for these items have been misplaced or lost over the years. I also remembered finding the bracket, used to mount the generator, broken right at the front hole where the bracket bolts to the engine block just in front of the front engine mount. This had been weld-repaired (rough repair at best) by a previous owner, and I found it broken when I first removed the generator over 25 years ago.
Is there a manual, diagram, etc. that shows these mounting components, including brackets and nuts and bolts, including bolt/nut diameter and thread size that I can refer to so I used the right fastener for the correct application?
As always, your input and direction are welcome.
The Factory Assembly Manual gives a lot of fastener part numbers but you'll need a Bill of Material to determine the fastener sizes & types. I seem to remember that stuff being posted here one about 1-2 years ago. Try doing search for it and hopefully someone saved it and could send it to you.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Do not use bolts longer than necessary. Seems like too long of a bolt on the coil bracket will hit a push rod or something.
http://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=952598
Gas Pumper
I went to ALOT of trouble. A LOT of trouble, learning the different sizes, styles and working of all of the fasteners on an AD. I did all of this research so that I could replace every single fastener with Stainless Steel. Not that its better in all respects. It has the advantage of not being a coating, but being 100% stainless thus no rust and no corrosion. If you do this, be warned there is about 4 types of Stainless that span from grade 2 to harder than grade 8. All of this was navigable due to a company Totally Stainless. Costs a lot more but the project I am working on nothing else is acceptable. It really pays to fully understand your needs. Don't use longer bolts than necessary, and make sure you have at least two threads sticking out beyond the nut. There are websites that explain the engineering aspects of fasteners. A little research goes a long way!
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Deve, we've all become aware that you are extremely meticulous
and as you've just posted, went to a LOT of trouble learning
the different sizes, styles and workings of all the fasteners
on an AD. Which indicates to me that unless you've committed it
all to memory, you must have made a list. So.... as the man
from Raleigh was asking, could you post it? I'm sure that a lot
of people would like to see one, and once you post it here,
it's here forever where everyone can refer to it. Thanks
Dave, I'm not sure but seems like Larry Kephart posted a list
like that in the adventures of Billy Bob series.
Maybe that's what you're thinking of.
Denny G
Sandwich, IL
In the Garage with BillyBob by LAROKE, LArry RObert KEphart
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Go here, http://chevy.oldcarmanualproject.com/parts/1929_54/039.HTM , and look at engine pictures. Then go to each group for part numbers if needed ( http://chevy.oldcarmanualproject.com/parts/1929_54/index.htm ).
If thats no help, go hear for a shop manual, http://chevy.oldcarmanualproject.com/index.htm
Joe
I liked reading about Billy Bob. That was one I started reading through when I first joined this group.
Ah, I figured the old professor would come thru, what a memory Timothy.
Tks and tks to the Billy Bob saga.
DG
Gas Pumper
Yeah, Larry is better at documenting stuff we can actually use than me. My fastener list is stalled at the chassis since that's where I am at right now. At the end, I will pull all of the receipts and put together a list.
Deve
The Think Tank
Page 1 of 2 1 2
