The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 members (Alainfrenchie54, 52_Ton, David C., BC59, Dragsix, 1 invisible), 295 guests, and 3 robots.
Forums47
Topics117,832
Posts942,914
Members43,050
Most Online1,229
Jan 21st, 2020
Image Posting Policy
zener diode 12vdc to 6vdc
#100882 Fri May 25 2007 09:10 PM
guys, will a nte 5118A 6V 5W zener diode work for my 50'AD gas gauge? i'm told 2W will work so will higher wattage rating cause a problem? thanks. grin
Re: zener diode 12vdc to 6vdc
#100883 Fri May 25 2007 09:57 PM
10 micron,
There was a post several weeks ago with some calculations for operating a 6 volt fuel gauge on 12 volts (OlBlue). His math showed 2.71 watts on 12 volts. To my limited knowledge, using a higher rated resistor or diode (watts) won't cause any problem...it's like using a heavier extension cord when your trimming the hedge.
Edit. Doesn't the voltage rating of your diode have to be at least that of your intended input voltage?
Edit/Edit. I just found a little Zener selector chart and put in values that would represent a voltage drop from 14.0 volts to approximately 6.0 volts. The diode you spec'd popped up! This tells me one important thing...I don't know a darn thing about this kind of stuff. grin
Stuart
#100884 Fri Jun 01 2007 12:01 AM
the one i found on ebay for fuel gauge's are .4amps at 12v. says each gauge needs seperate one. for the wiper motor you need a 1.5 ohm ceramic resistor. they claim the ceramic resistor will run a heater blower at 4amps/25 watts max.
#100885 Tue Jun 05 2007 01:11 AM
The heck with ebay...just go down to your local
electronics store or even (shudder) radio shack...
I know there are a couple of good ones in the sea-tac area...
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
#100886 Tue Jun 05 2007 01:48 AM
It's time again to put my foot in my mouth. I am not sure I understand this 'Zener diode' deal. I think I know what a diode does, and I think that the special Zener diode will conduct current in the reverse direction when the voltage reaches a critical peak...isn't this what sets a Zener apart from a standard diode.
Every poop sheet I have seen that showed how to make a small voltage reducer using a Zener diode also included a small resistor in parallel (I think). How can a diode reduce voltage...I thought a diode was a one way gate so to speak.
Stuart
#100887 Tue Jun 05 2007 04:23 AM
A zener in series with the load will pass everything higher than its zener voltage. If you had a six volt zener with a twelve volt system, typically 14.3 V while charging, you would see 8.3 V at the load. A current limiting resistor in series with the load, with a six volt zener to ground between the resistor and the load, would present six volts to the load.
#100888 Tue Jun 05 2007 04:32 AM
Wow, that was easy...thanks Baldy! I must have been absent, or in reform school the week they taught this at the asylum. smile
Stuart
Moderated by  Rusty Rod
