The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (Greg C, Pete V, rickmg, 3800GUY, dougs, Wheelie), 85 guests, and 3 robots.
Forums60
Topics124,660
Posts1,006,225
Members44,993
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Is there a difference between a half-ton and a 2 1/2 ton cab?
#1002731 Wed Jan 29 2014 05:21 AM
I'm looking into buying a 2 1/2 ton truck just for the cab but Is there a difference between a 1/2 and a 2 1/2 ton cab?
Re: Is there a difference between a half-ton and a 2 1/2 ton cab?
5WINDOWJOHN #1002734 Wed Jan 29 2014 05:42 AM
There are a couple differences in small items. If the truck has a floor mounted parking brake the hardware for the foot operated brake will need to be sourced, up to and including the firewall mounting bracket. If the truck has a 2-speed rear end there will be some additional hardware and holes on the firewall to consider. Dimensionally they are the same, mounts changed in 1949 to frame shackles from a center pivot and bumpers. Trucks in the U.S. are rated to 2-tons usually but in other markets can be equipped for ratings as high as 5-tons. All my comments are for AD's. Your best bet is to find a similar year cab so the changeover shares common parts, 47-48 or 49-53 or 54-55 1st Series.
http://www.flickr.com/photos/advance-design_parts_co/9527752160/in/set-72157631872034068
5WINDOWJOHN #1002747 Wed Jan 29 2014 06:52 AM
Thanks Brad! The 2 1/2 ton truck is a 1947 advance design. It has a two speed rearend, emergency hand brake lever, and I would like to put the cab on a half ton frame with a flatbed and make it into a swapmeet hauler. I know the front fenders have a bigger wheel well and the grille is longer, but is the rear of the 2 1/2 ton cab wider, where the frame rails come out? And would 1/2 ton front fenders look funny and would they fit on a 2 1/2 ton cab without making any modifications? Thanks again
5WINDOWJOHN #1002764 Wed Jan 29 2014 01:41 PM
Bubba
5WINDOWJOHN,
Are you referring to a GMC 2.5 ton truck (1947, New Design)?
Here are the 1947 Chevrolet Advance-Design models.
If you are referring to the A-D cab, it is the same for all sizes of Chevrolet trucks. The smaller fenders and the larger fender will bolt onto that cab.
Fenders looking funny might just be in the eye of the viewer/beholder. What size wheels/tires will you be using (1/2 ton 15"/16" wheels or bigger truck 20" wheels)? Match the fenders to the wheels.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Moderated by  Justhorsenround
