We are still asking:
What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures and No BOTS.
So ...
What did you get done on your Bolt today????
Oh Lord, I just gotta find it....
Forums60
Topics127,472
Posts1,031,731
Members45,787
Most Online1,229 Jan 21st, 2020
 Re: Exhaust manifold 235 question
OP
Thanks DADS50. Now I know. Guess you were using a heat gun or hair dryer in the video?
OP
Thanks Jerry. I have squirted oil in the spark plug ports a long time ago and would periodically turn the engine over manually. I have also had the valve cover off and witnessed all the valves moving. I can actually turn the engine over by hand with the flywheel installed, but will make sure it turns over manually before putting any fire to it. Appreciate the good coaching!
OP
Thanks for your tip Mr. deluxe54PANEL. Going to get some good penetrant today and start the process.
Guess you were using a heat gun or hair dryer in the video? ...heat gun...
I saw this the other day and thought..."darn they made a tech tip!" Heat riser maintenance
OP
CASO,
Way to go. I'll study this a lot closer. Right now, I am hitting mine about every 4 or 5 hours with some good penetrating spray and a couple of taps from either side with a light tap of the hammer. Just trying to loosen it up from years in the same position.
John in Raleigh
