The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Keep your restoration going
Keeping your resto going
A good bit of advice nestled in the FAQ page.
Don't
Irwin Arnstein working on his
1959 Chevy 1-Ton
Read the article.
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (Bill Hanlon, Gdads51, Hotrod Lincoln, 3B, JW51, 49nut), 123 guests, and 3 robots.
Forums59
Topics128,524
Posts1,041,198
Members46,036
Most Online1,229
Jan 21st, 2020
Previous Gallery
Next Gallery
#1415153 Mon Jun 28 2021 02:56 AM
6 Images
1958 Chevrolet 3600 NAPCO
Family owned since new, 235, 4 speed, line built NAPCO, Cardinal Red/Bombay Ivory trim. Mods - power master cylinder, 285/75/16 radial tires, alternator, high tone horn, fuel cell located behind rear axle.
5 Comments
It's hard to give me truck envy: but this does it.
I bet it's a workout to steer those tires!
'59 Chevy Suburban, NAPCO
Looking at your story in the gallery, it looks like you did a lot of good stuff on this truck. It is a real beauty.
Do you know where to find tech specs for the Napco conversions? I have been curious about it for a long time, but can't find a decent resource for hard info. Things like the new spring rates/sizes, how much the body is lifted compared to the 2WD, that kind of thing.
58 Apache, long bed fleetside, V8 w/SM420
Drivable but the rear axle needs work.
Here's some specs:
http://chevy.oldcarmanualproject.com/chevyresto/58t099.htm
Mine has 6" lift blocks on the rear axle.
That is a Beautiful truck ! Thanks for sharing with us !
Jim
http://s1107.photobucket.com/albums/h397/justjayne21/
50 Chevy 3100
77 International Scout ll
I will be converting the headlights to a relay controlled setup this summer. I ran dedicated ground wires from the bulbs and still have kick-out from the headlight switch overload. I bought a kit from Daniel Stern Lighting that has HID elements inside GE bulb Pods sourced from Belgium; they look like OEM if you don't put your head next to them.... I am excited to drive it this summer and not have the lights kick off. Now all we have to do is have our administration fix the gas crisis.
I replaced the BFG radials with Cooper Discover radials (made in Ohio!!!) and went up one size to gain some more diameter. 285-75-16...
It doesn't steer to bad with the tires set to 50 psi!
The truck is a line built NAPCO from Willow Run Michigan, Chevrolet started this in mid production year for the 1958 truck.
Not a show goes by that someone asks me what kind of a lift I have on it.......
Moderated by  hardshell, J Lucas
