The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members (Paul Mullen, Gooberdog, Jon G, mule 1951, 3B, Justhorsenround), 78 guests, and 3 robots.
Forums60
Topics125,462
Posts1,013,060
Members45,239
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Previous Gallery
Next Gallery
1948 5-Window 3100
#1413068 Tue Jun 08 2021 07:51 AM
Red dot, center of chest ...
1948 5-Window 3100
My truck won 2nd in class at the Kansas City show a few years back (got beat by a Stovebolter with a magnificent school bus), but it's not a trailer queen. This truck is all original steel except for the tailgate.
Frame-off resto-mod, new corner glass, "modern" paint job with clear-coat (cab, fenders, bed pieces were all painted separately off the truck), too many powder-coated parts to mention them all, lowered four inches
Engine: 235 bored.030 over with a mild Isky cam, modified for a full-flow oil filter, ceramic-coated "original" Fenton headers (came off an old 60s hot rod), ceramic-coated Offy 2x1 manifold, two Model B Rochester carbs, powder-coated air cleaner cover, valve cover, and side cover, electronic ignition (not Petronix - actual EI), Vintage Air A/C, electric fan (switch under dash), dual exhaust with Thrush mufflers
Brakes: 4 wheel power disc brakes - the front has a kit, the rear is out of a Firebird (I think it was an '84), power booster is mounted to the frame on the driver's side
Drivetrain: S-10 Borg-Warner T-5 with overdrive, 3.73 limited-slip POSI rear, floor-mounted shifter between the two bucket seats, this truck will run 65 all day long at 2,000 RPM with air (and has), chrome diff cover, Goodyear P215/R15-75 radials, slotted mags (I don't know the make, but they remind me of the old Cragers from the 60s.)
Suspension: Front mono-leafs from Patricks, rear stock springs with mounts reversed, gas shocks all around
Steering: stock, no power, with a very large steering wheel to make slow turning easier, Ididit column with tilt and turn-signal
Battery: mounted under the frame on the passenger side in a tray that can be lowered for service, optima red-top AGM battery with Optima digital trickle-charger
Interior: adjustable bucket seats with seat belts, tan and black interior, carpeted floor with tan and black Chevy mats, dolphin white-faced electronic speedometer, dolphin white-faced four-gauge cluster (oil pressure, water temperature, volts, fuel), Sunpro Super Tach II mounted under the dash, no radio, no stereo, no DVD (see - there's still things you can do to this truck)
Bed: oak boards, marine-varnished, stainless hardware, stainless hidden latch tailgate from Mar-K
Stainless: rear taillight housings, locking gas cap, door trim, bolts everywhere, including bow-tie stainless bolts on the upper radiator housing mount, stainless braided fuel lines
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
7 Comments
Re: 1948 5-Window 3100
baldeagle #1413081 Tue Jun 08 2021 12:09 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Beautiful truck Paul. I hope it doesn’t leave the Stovebolt family.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
Justhorsenround #1413267 Wed Jun 09 2021 05:48 AM
Thank you, Justhorsenround. I hope so too.
Paul Schmehl CI 6
geek@stovebolt.com
baldeagle #1421571 Mon Aug 23 2021 12:22 AM
I sold my truck last month to a guy who absolutely loves it and drives it every week. I'm trying to get him involved in Stovebolt, but he's not much for the internet.
Paul Schmehl CI 6
geek@stovebolt.com
baldeagle #1422587 Wed Sep 01 2021 03:51 PM
That was a nice looking truck and loved what you did with the engine. Are you working on a new project? I was wondering if you could help me out with a question pertaining to the T5 transmission. Did you use the original clutch fork and bellhousing or did you have to change it out to accommodate T5?
1950 Chevrolet 1/2-Ton 3100
baldeagle #1422619 Wed Sep 01 2021 08:23 PM
I'm not working on any projects right now.
I used the same bellhousing and clutch parts that came with the truck - I think. It's been years since that work was done. The shifter was back so far that it probably would have hit the bench seat when shifting. (I had buckets.) I do know that I did not have to buy a new bellhousing.
Paul Schmehl CI 6
geek@stovebolt.com
baldeagle #1430741 Sat Nov 20 2021 02:37 AM
Moderated
My 1st post here - what a beautiful truck! Gives me encouragement to make mine better.
baldeagle #1430986 Mon Nov 22 2021 04:45 PM
Thank you, 51 Shorty.
Paul Schmehl CI 6
geek@stovebolt.com
Moderated by  hardshell, J Lucas
