Remember
The old Bulletin Board?
click to enter
The old Bulletin Board has been removed from the server. And with recent "spring" cleaning, we are removing links back to it. The BB is still out in cyber space (to some extent) thanks to The Wayback Machine.
Oh Lord, I just gotta find it....
Forums59
Topics128,108
Posts1,037,350
Members45,936
Most Online1,229 Jan 21st, 2020
OP
Red dot, center of chest ...
1948 5-Window 3100
My truck won 2nd in class at the Kansas City show a few years back (got beat by a Stovebolter with a magnificent school bus), but it's not a trailer queen. This truck is all original steel except for the tailgate.
Frame-off resto-mod, new corner glass, "modern" paint job with clear-coat (cab, fenders, bed pieces were all painted separately off the truck), too many powder-coated parts to mention them all, lowered four inches
Engine: 235 bored.030 over with a mild Isky cam, modified for a full-flow oil filter, ceramic-coated "original" Fenton headers (came off an old 60s hot rod), ceramic-coated Offy 2x1 manifold, two Model B Rochester carbs, powder-coated air cleaner cover, valve cover, and side cover, electronic ignition (not Petronix - actual EI), Vintage Air A/C, electric fan (switch under dash), dual exhaust with Thrush mufflers
Brakes: 4 wheel power disc brakes - the front has a kit, the rear is out of a Firebird (I think it was an '84), power booster is mounted to the frame on the driver's side
Drivetrain: S-10 Borg-Warner T-5 with overdrive, 3.73 limited-slip POSI rear, floor-mounted shifter between the two bucket seats, this truck will run 65 all day long at 2,000 RPM with air (and has), chrome diff cover, Goodyear P215/R15-75 radials, slotted mags (I don't know the make, but they remind me of the old Cragers from the 60s.)
Suspension: Front mono-leafs from Patricks, rear stock springs with mounts reversed, gas shocks all around
Steering: stock, no power, with a very large steering wheel to make slow turning easier, Ididit column with tilt and turn-signal
Battery: mounted under the frame on the passenger side in a tray that can be lowered for service, optima red-top AGM battery with Optima digital trickle-charger
Interior: adjustable bucket seats with seat belts, tan and black interior, carpeted floor with tan and black Chevy mats, dolphin white-faced electronic speedometer, dolphin white-faced four-gauge cluster (oil pressure, water temperature, volts, fuel), Sunpro Super Tach II mounted under the dash, no radio, no stereo, no DVD (see - there's still things you can do to this truck)
Bed: oak boards, marine-varnished, stainless hardware, stainless hidden latch tailgate from Mar-K
Stainless: rear taillight housings, locking gas cap, door trim, bolts everywhere, including bow-tie stainless bolts on the upper radiator housing mount, stainless braided fuel lines
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Beautiful truck Paul. I hope it doesn’t leave the Stovebolt family.
Martin '62 Chevy C-10 Stepside Shortbed (Restomod in progress) '47 Chevy 3100 5 Window (long term project) ‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily” ‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one! Support those brave men/women who stand the "Thin Blue Line"! Hug a cop! USAF 1965-1969 Weather Observation Tech (I got paid to look at the clouds)
OP
Beautiful truck Paul. I hope it doesn’t leave the Stovebolt family. Thank you, Justhorsenround. I hope so too.
OP
I sold my truck last month to a guy who absolutely loves it and drives it every week. I'm trying to get him involved in Stovebolt, but he's not much for the internet.
That was a nice looking truck and loved what you did with the engine. Are you working on a new project? I was wondering if you could help me out with a question pertaining to the T5 transmission. Did you use the original clutch fork and bellhousing or did you have to change it out to accommodate T5?
1950 Chevrolet 1/2-Ton 3100
OP
I'm not working on any projects right now.
I used the same bellhousing and clutch parts that came with the truck - I think. It's been years since that work was done. The shifter was back so far that it probably would have hit the bench seat when shifting. (I had buckets.) I do know that I did not have to buy a new bellhousing.
Moderated
My 1st post here - what a beautiful truck! Gives me encouragement to make mine better.
OP
