The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Spring is here!
If you are bringing the old truck out of winter storage, or up from the woods, be sure to check the Tech Tip for a few helpful hints.
If you have some work to do before you go cruising, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Some New
Some Vintage
Many in Production
Will be updating all year around!
Who's Online
8 registered (78buckshot, dunfire, 5 Window 9434, coilover, Jimmie D, Justhorsenround), 450 Guests and 4 Spiders online.
Forum Stats
39,646 Registered Members
48 Forums
105,730 Topics
Most users ever online: 940 @ Tue Apr 04 2017 09:52 PM
Today's Birthdays
big 51, chevypanel52, ray1958, RickA
New Reply
Topic Options
#863394 - Sat Jun 30 2012 10:06 PM World Class T5 Bell housing fit
Gippetto Offline
Loc: Massachusetts
Hello,
I am planning to use a T5 from a 94 or so S10. I read that was the first year the world class was uswd in the S10. Previous were NWC.
My question is will it fit a 48 GMC belhousing? The truck had a '55 Chevy 235 bolted to original drive train.
Any info is appreciated. Also, I am looking for WC T5 that will work for me.
Top
#863415 - Sat Jun 30 2012 11:19 PM Re: World Class T5 Bell housing fit [Re: Gippetto]
Spareparts2 Offline
Loc: Lansing, Ks
It will require an adapter and they are available from several vendors here.
_________________________
You Learn more Listening than Talking
Top
#864163 - Tue Jul 03 2012 10:24 PM Re: World Class T5 Bell housing fit [Re: Spareparts2]
GMCFreak Offline
Loc: Paducah,KY
Go to 5speeds.com. The world class T5's were introduced in the late 80's. Also, the 82-92 T5's bolt right up to the Chevrolet/GMC bellhousings. In some cases you have to have a spacer betwen the trans and bellhousing, or cut some material off the end of the pilot shaft, and also the throwout bearing sleeve. This depends a lot on the clutch disc you use. On my first conversion I used an S10 9" disc and the center hub of the disc was thick enough to require cutting the throwout shaft. I have since changed over to two Camaro T5's one WC and one NWC. If you can find a pre 87 S10 tailshaft housing, you can build a Camaro WC with the shifter in nearly the same place as the original 4 speed.
Top
#864166 - Tue Jul 03 2012 10:37 PM Re: World Class T5 Bell housing fit [Re: Gippetto]
BC59 Offline
Loc: N.E. Oregon
S10 never got the WC trans, only NWC. These were 173ci (2.8L) v-6, inline 4 gas & diesels. Many of us run them in 1/2 pickups behind inlinesand they seem to hold up well. Later S10 (4.3 v6) used NVG3500 while 4cyls got NVG1500.
BC
Top
#864237 - Wed Jul 04 2012 09:00 AM Re: World Class T5 Bell housing fit [Re: BC59]
Wrenchbender Ret. Offline
Loc: Lenexa Ks.
Like Freak says, if you make a few modifications you will not need an adapter. The WC t-5 was used in some 93-95 S-10s. I have 2 of them. The 89 up & some 88 had the electronic speedo drive. You cannot use the original speedo with them without a special converter that is expensive. The NWC T-5 is just about as good. I have used them behind 350 v-8s with no problems.
1956 Chevy 1/2-Ton Pickup
Top
#864253 - Wed Jul 04 2012 10:56 AM Re: World Class T5 Bell housing fit [Re: Wrenchbender Ret.]
Brian_Ostner Offline
Loc: NJ
Wrenchbender,
I see you stated that you have used the T-5 trannys behind the chevy v-8's with no problems.
My son and I will be putting a pretty stout 350 in our 51 1/2 ton. We are still undecided on the tranns, although we do already have a T-5 out of a donor S-10 that we picked apart for parts.
Were the V-8's you used stock or no? Also, were you pretty easy on em' or did you drive it like you stole it? We plan on hard acceleration and plenty of low end power. I believe our donor S-10 was a 1989 and it does have the electronic speedo drive . (yuck) I do not want to buy the converter, expensive. Also, we like the original gauges that came in the truck. Would a competent tranns shop be able to open up the tailshaft and change it over to mechanical drive? If it is not too hard, we could even do it. Any sugestions? Thanks, Brian and Grant
Top
#864358 - Wed Jul 04 2012 06:37 PM Re: World Class T5 Bell housing fit [Re: Brian_Ostner]
Loc: Lenexa Ks.
I use the basic Goodwrench 350 with Edelbrock intake & Q-jet 4brl. Stock ramhorn ex. manifolds with duals. I don't drive them hard but I do put my foot in it once in a while. I wouldn't recommend the T-5 for heavy duty service but the Mustang guys don't baby them.
To change to the mech. speedo you have to get the speedo gears & the rear housing from the earliar mech. drive model. If you find one of those you might as well use it. They are getting hard to find lately.
Top
#864633 - Thu Jul 05 2012 09:31 PM Re: World Class T5 Bell housing fit [Re: Wrenchbender Ret.]
GMCFreak Offline
Loc: Paducah,KY
Remember that the T5's were originally behind the 305 HO V8s and some 350s in the B body cars (Camaro & Firebird). These T5'sw used a larger (21 or 26 Spline?) Input shaft and would handle more Torque as long as you're not talking 15 inch wide slicks on a Posi rear end and running at the strip every weekend. I'm running a NWC T5 behind a hot rodded GMC 270 (.080 over, Venolia 9:1's,Cam , & Edelbrock 4 Barrel. Been abusing it every chance I get with a 3.42 single track rearend and 275.70 tires with no problems for nearly a year. Before that I had a Camaro WC behind a GMC 302 with all the same and 3 Ford 94's on a Howard Intake for about 6 months with no troubles. Hope that answers your questions. Finally you really need a 82-86 S10 tailshaft housing and shifter on the Camaro transmission to move the shifter up where it belongs.
Top
Moderator:  SWEET
