The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Indianapolis Fabrications
Talk to Randy Domeck
See what they
can do
for you
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
47 registered (55 SHAKER, 66flea, 52Carl, Allen Lane, 4 invisible), 636 Guests and 4 Spiders online.
Forum Stats
39,736 Registered Members
48 Forums
106,167 Topics
Most users ever online: 940 @ Tue Apr 04 2017 09:52 PM
Today's Birthdays
52 pick-up, coppertinman, daviper1996, deimos540, Mr. Pickett, Rick In VA
Image Posting Policy
Page 1 of 2 1 2 >
New Reply
Topic Options
#998026 - Wed Jan 08 2014 11:42 PM STP
49Chief Offline
Loc: Kansas City
Has anyone have any thoughts about using STP Oil Treatment as a supplement for ZDDP in their oil ? The bottle says it has ZDDP in it but I don't know how much.
_________________________
Life is to short to be stuck in a rut.
"One thing about trains, it doesn't matter where there going, what matters is, deciding to get on." - Polar Express
God is great, Beer is good, and people are crazy.
Top
#998027 - Wed Jan 08 2014 11:47 PM Re: STP [Re: 49Chief]
Hotrod Lincoln Online
Loc: Dellrose, TN
Way back in the dark ages, I used STP as an assembly lube on engine overhauls. Every engine I built that way had some sort of oil-related failure and didn't go the expected distance. Just to prove to myself that it was just a coincidence, I built one more engine with STP. That one stuck the oil pump relief valve open and trashed a crankshaft. Now I wouldn't put STP in a lawn mower with a rod knock!
Edited by Hotrod Lincoln (Wed Jan 08 2014 11:49 PM)
Who says I live in a rough neighborhood- - - - -?
Just because I'm a tail gunner on a beer truck, maybe?
"He ain't even got a noddin' acquaintance with the truth- - -let alone a speakin' one!"
Top
#998030 - Thu Jan 09 2014 12:08 AM Re: STP [Re: 49Chief]
49Chief Offline
Loc: Kansas City
Bought a 87 F150 5.0 that had 105k miles from a guy that had it since new. I kept the same oil change regimen he did. (Mobil Del-vac 15w40 and a bottle of STP) Don't ask me why I just done it. With a name brand filter, Motorcraft mostly. When rust finally ate up the truck to where you could not drive it anymore the engine had 367k miles and still going strong. Just sayin.
Top
#998033 - Thu Jan 09 2014 12:23 AM Re: STP [Re: 49Chief]
J M Offline
Loc: Gunnison Colorado
I worked for awhile in a small independent shop. We had a costumer that wanted a can of STP put in his car with each oil change. We had to pull the pan for some reason and there was about two inches of gunk in the bottom of the pan. I don't put it in anything I own.
Jim
Edited by J M (Thu Jan 09 2014 12:32 AM)
Top
#998036 - Thu Jan 09 2014 12:39 AM Re: STP [Re: 49Chief]
Jim Sears Offline
Loc: MA
I have used STP for assembly lube for decades. Best thing in the world if you aren't doing a rebuild and reinstall to run in 48 hrs. Everything else will run off in no time, you can take the engine apart weeks later (without running it) and there is still a coating of STP on everything.
With newer engines running tight tolerances and new oil technology, I've stopped running additives at all.
When I had a fleet of rental VW Vanagon campers (water cooled)in the early 2000's, I always used used STP to rebuild, but with the first oil change I would add a teflon additive like Tplus or T-fal I think were the names.
That got a lot of customer abused buses home, badly overheated, low on oil, pushed to the limits, that normally should have stopped running.
The engines I bought for rebuilding had been through the same thing but they had spun bearings, seized pistons etc.
Just my experience.
Top
#998042 - Thu Jan 09 2014 01:01 AM Re: STP [Re: 49Chief]
crenwelge Offline
Loc: Fredericksburg, Texas
We used to sell a lot of STP to people with old worn out engines. It quietened them down, cut down on oil consumption and raised the oil pressure. We even used it in our old GMC gassers and 855 Block Cummins engines to make a few more trips until we overhauled them. It needs to be added slowly with the motor hot and running. Otherwise a blob of it will settle in front of the oil pickup and starve the engine for oil. I think it has kind of outlived its usefulness, but it kept a lot of old engines going a little while longer back in its heyday. I still use ZDDP on flat tappet engines. My father sold an oil that had zinc in it. It was something that was developed during the war and was way ahead of its time.
Top
#998044 - Thu Jan 09 2014 01:17 AM Re: STP [Re: 49Chief]
Truckrolet Offline
Loc: Wa
Like posted above, I've seen STP save a few old worn out aircooled engines (VW). As a youngster I remember one of the mechanics at the FBO I worked at using STP for a continental aircraft engine overhaul. Approved or not for aircraft it was his choice, he said he's the one signing off the paper work.
No more trucks
Top
#998074 - Thu Jan 09 2014 10:02 AM Re: STP [Re: 49Chief]
Justhorsenround Offline
Loc: Central, Oklahoma
Used STP mixed with 2 qts of 30wt oil in every old mower engine I brought back to life from the scrap pile. Every one started on the first pull and I never had to add any oil to them again. Sold hundreds of those old mowers for $25 over the course of 4-5 years.
'48 Chevy Suburban Street Rod
"I fought the law and the law won" now I are a retired one!
48 Burb
Top
#998106 - Thu Jan 09 2014 12:16 PM Re: STP [Re: 49Chief]
Whitelightning Offline
I had always heard STP wasn't good to use in air cooled engines... Go figure....
Top
#998217 - Thu Jan 09 2014 08:27 PM Re: STP [Re: 49Chief]
cheezwhiz Offline
Loc: Pacific NW
I don't have any doubt that STP used to have its place, but I wouldn't be surprised if it has been reformulated to the point where it doesn't do our old engines much good. My short answer would be to use a flat tappet additive and my long answer would be to go to the Bob is the Oil Guy forums (BITOG). They will have you enrolled in undergraduate chemistry courses before long :)
Top
Page 1 of 2 1 2 >
Moderator:  53moneypit, Woogeroo
