The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
37 registered (49 3100, 1962C10, 3800rao, 1953 panel, 3 invisible), 363 Guests and 10 Spiders online.
Forum Stats
39,539 Registered Members
48 Forums
105,776 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
briang, emerson, finally have one, levi_69, paul stewart, Wild Turkey
Image Posting Policy
New Reply
Topic Options
#952750 - Wed Jun 26 2013 07:23 AM brakes on 1948 3/4 ton chevy truck
busjockey Offline
Loc: texas
I am in the process of rebuilding the front axle of my truck. I can not find new brake drums for my truck. My brake drums are shot. I am going to drive this truck daily. I am considering changing the front axle to a 1953 3/4 ton axle because of not being able to find the brake drums. If I could find drums would leave alone. Does anyone have any experience with this problem? I am in need of advise. Thanks.
Top
#952774 - Wed Jun 26 2013 09:56 AM Re: brakes on 1948 3/4 ton chevy truck [Re: busjockey]
Brad Allen Offline
Loc: Salt Lake City, Utah
1947-50 3/4-ton drums are impossible to find NOS and I am not aware of any new manufacturing of them. I bought another early truck just for these items recently for my own spares. I lucked out by getting 3 good drums plus a full set of near new shoes. I know the change you are contemplating has been done by others for similar reasons. It is not difficult if you have a donor set-up and the later style drums are widely available though they are not cheap. If you do change I would recommend all new u-bolts it is cheap insurance on 60+ year old parts.
Top
#952775 - Wed Jun 26 2013 10:02 AM Re: brakes on 1948 3/4 ton chevy truck [Re: busjockey]
busjockey Offline
Loc: texas
Going to change. Will be changing all suspension bolts while doing this. I either need to find used axles or find out which parts i need to change on mine. All advice welcome.
Top
#952787 - Wed Jun 26 2013 11:22 AM Re: brakes on 1948 3/4 ton chevy truck [Re: Brad Allen]
EdPruss Offline
Loc: Longmont, CO
Might look into going to discs, especially since your daily driver. Lots of info here.
Top
#952811 - Wed Jun 26 2013 01:01 PM Re: brakes on 1948 3/4 ton chevy truck [Re: busjockey]
Brad Allen Offline
Not sure if this applies to the 3/4-ton but it should be close.
http://www.stovebolt.com/techtips/adbrakes.htm
Top
#952826 - Wed Jun 26 2013 02:20 PM Re: brakes on 1948 3/4 ton chevy truck [Re: busjockey]
Ghostrider Offline
Loc: Binghamton, NY
busjockey, front brakes from '53 to '59 3/4 and 1 ton trucks can be fitted to your front axle. You need the brake assemblies from the backing plates out. You'll have to enlarge two holes on your spindles from 7/16" to 1/2" to bolt them up.
_________________________
Steve
'49 3800
'52 3600
Top
#953003 - Thu Jun 27 2013 07:40 AM Re: brakes on 1948 3/4 ton chevy truck [Re: busjockey]
busjockey Offline
Loc: texas
so what I am understanding my spindles will work just modify two holes to bolt on backing plates? Do you know anything about the rear brakes. Do I need a 53 axel or can we just change the backing plates out on that as well?
Top
#953015 - Thu Jun 27 2013 08:32 AM Re: brakes on 1948 3/4 ton chevy truck [Re: busjockey]
EdPruss Offline
Loc: Longmont, CO
You probably have an Eaton axle, GM 14 bolt FF axles are cheap and plentiful, lots of ratios, modern brakes, late ones w/ discs.
Top
#953055 - Thu Jun 27 2013 10:54 AM Re: brakes on 1948 3/4 ton chevy truck [Re: busjockey]
Ghostrider Offline
Loc: Binghamton, NY
Swapping Bendix brakes onto your rear axle housing isn't going to work out so well due to different drum and backing plate offsets. Would involve cutting/grinding/welding or improvising some spacers to line things up. If you have access to a '53 rear, I would sooner swap that in if your rear drums are truly not serviceable.
Steve
'49 3800
'52 3600
Top
#953058 - Thu Jun 27 2013 11:33 AM Re: brakes on 1948 3/4 ton chevy truck [Re: Ghostrider]
busjockey Offline
Loc: texas
JIM CARTER SAYS THEY HAVE REAR DRUMS FOR THE TRUCK NEW WOULD THERE BE A PROBLEM WITH BENDIX IN FRONT AND STOCK IN REAR?
Top
Moderator:  cletis
