The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
58 registered (49nut, 3B, 5 Window 9434, 48bigtrucks, 1953 panel, 3 invisible), 690 Guests and 5 Spiders online.
Forum Stats
39,515 Registered Members
48 Forums
105,692 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
40_chevy, bigfoot, chevy1938, Chief36chevy, james b., jots, K-FLY, lightfoot, ruhere, White Elephant
Image Posting Policy
Page 2 of 3 < 1 2 3 >
New Reply
Topic Options
#949168 - Sun Jun 09 2013 11:37 AM Re: Clutch head screws/bolts replacement [Re: oldgreen51]
johntsmith Offline
Loc: Tampa Bay FL
We have a firm rule - clutch heads are only turned one way - counterclockwise......
_________________________
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Top
#949397 - Mon Jun 10 2013 01:45 PM Re: Clutch head screws/bolts replacement [Re: oldgreen51]
52Carl Online
Loc: Virginia
For me, I have a thing for clutch head screws! I don't care if they might be inferior or a pain sometimes. They are unique and iconic to these old vehicles. I am always looking for places to use them where they don't belong, like inner fender-to-fender, bed front-to-bedsides, top radiator pan. They're just TOO COOL! My early 49 AD has them to hold on the VIN plate. They are real small and possibly original, as the screws are much smaller than the holes for the rivets that I'm used to seeing used to attach VIN plates.
Top
#949470 - Mon Jun 10 2013 05:29 PM Re: Clutch head screws/bolts replacement [Re: oldgreen51]
tclederman Offline
Loc: Jarvisburg, NC
There is nothing inferior about clutch-head screws. They have superior torque/grab characteristics over slotted-head and Phillips-head screws.
People either do not have the correct drivers, or they have the mistaken notion that removing rusted clutch-head screws is more difficult than removing rusted slotted/Phillips screws. Removing any rusted screw is difficult.
Carl, you might be interested in this Jim Carter article on clutch head screws on ID plates through 1950.
Top
#949525 - Tue Jun 11 2013 12:12 AM Re: Clutch head screws/bolts replacement [Re: oldgreen51]
Truckrolet Offline
Loc: Wa
Where to get the screws?
No more trucks
Top
#949589 - Tue Jun 11 2013 07:23 AM Re: Clutch head screws/bolts replacement [Re: Truckrolet]
CASO Offline
Loc: Warrenton, Oregon
McMaster Carr or Fastenal have them but make sure you order the right kind. There are 2 types of Clutch head screws...
Give me ambiguity
or give me something else
Top
#949764 - Tue Jun 11 2013 06:53 PM Re: Clutch head screws/bolts replacement [Re: oldgreen51]
Rich'sToys Offline
Loc: Janesville, Mn
I actually looked on McMaster and couldn't find anything. This surprised me, as they have EVERYTHING! I found the bits, but no screws. If they're there I missed them somehow.
Rich
'47 Loadmaster
The indignation of politicians is NOT a good measure of the gravity of any situation!--Paul Harvey
I would rather live my life as if there is a God and die to find out there isn't, than live my life as if there isn't and die to find out there is.
Top
#949770 - Tue Jun 11 2013 07:09 PM Re: Clutch head screws/bolts replacement [Re: oldgreen51]
tclederman Offline
Loc: Jarvisburg, NC
As Grigg pointed out a while ago, McMaster-Carr has the bits at reasonable prices.
I do not see clutch-head bolts/screws (either type) in the McMaster-Carr or Fastenal catalogs. Maybe CASO will tell us how to search for them?
Truckolet,
- Did you look at the sources at the link that Lonnie posted, above?
- Did you check out the Restoration Specialties catalog? Page 182?
Top
#949824 - Wed Jun 12 2013 05:12 AM Re: Clutch head screws/bolts replacement [Re: oldgreen51]
CASO Offline
I guess I was thinking bits... so I did a glook up and heres a few Clutch head screws :search
Give me ambiguity
Top
#949888 - Wed Jun 12 2013 10:02 AM Re: Clutch head screws/bolts replacement [Re: Lightholder's Dad]
simplex Offline
Loc: N LA county
Originally Posted By Lightholder's Dad
Oldgreen51,
I kind of like the clutch head screws and bolts, after completely disassembling and reassembling an entire truck ('50 COE). I much prefer them over slotted or phillips heads. To work with these fasteners you need the proper drivers or bits and before you attempt to mess with an old clutch head fastener, you need to clean out the hole. The sides of the hour-glass shaped hole are straight, so to get the driver in there all the way, you need to clean it out with a sharp awl or other tool. Get all that rust, grease and dirt out first. If done properly, you will either remove the fastener or snap the head off the fastener, before it slips out. What more could you ask?
If originality is not important then use whatever is handy. I would go with a torx, square hole or other straight sided fastener before I would use a slotted head screw or bolt. I was trying to retain an original appearance to my truck so I bead blasted and reused all the fasteners that were not damaged upon removal.
It takes many years of carefully removing the original clutch head hardware to come up with enough extras to get you through an original restoration.
http://img.claspics.com/w8cp5hb/hhuvt3pj/1371063541-830.JPG_m.jpg?1371063546
Top
#949897 - Wed Jun 12 2013 10:12 AM Re: Clutch head screws/bolts replacement [Re: oldgreen51]
Materman Offline
Loc: rural oklahoma
since we are talking about these boogers, how in the world do you get one out that has been stripped?
Indy wink
1955 2nd chevy 4400 series 1.5 ton, affectionately named Mater
1969 GMC Heavy Half LWB fleetside with TH400 305 v6 named Blue Thunder
Miss Daisy, the 1949 Dodge Coronet 4 door with Gyromatic transmission
Project While-I'm-at-it, the 1972 GMC Sprint 350 v8 with th400
Some people are like glo sticks, I just want to snap them, and shake the snot out of them until the light comes on!!
Top
Moderator:  cletis
