The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
3 registered (Gabes-trucks, Cosmo, 1 invisible), 408 Guests and 4 Spiders online.
Forum Stats
39,284 Registered Members
48 Forums
104,820 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
35pickup, 68haywagon, Bubbles, buxman66, Franklin C. Cooley, Larry Shaddy, LimeyC10, mark8544, mike boyle, Pee-Wee, peter 60 stepsid
Image Posting Policy
Page 1 of 2 1 2 >
New Reply
Topic Options
#910763 - Fri Jan 11 2013 05:56 AM Window Regulator Roller Replacement - '47 3100
BDammers47 Offline
Loc: South Carolina
Hi Folks,
I've done a search, but did not find what I'm looking for.
I've got window regulator replacement roller kits (CP 18-795). Removing the old shafts seems simple enough (drill out/off stake and push out). However, what is recommended procedure for staking the new shafts? Peening with a hammer? Press in a vise? Do I need a large radius tool for the stake?
Beyond that, can anyone provide some advice on pitfalls to avoid or how-to tricks?
Please advise and many thanks for the help.
_________________________
1947 3100 Advanced Design
A Work in Progress
Never, never, never, never give up. - Churchill
Top
#910889 - Fri Jan 11 2013 01:03 PM Re: Window Regulator Roller Replacement - '47 3100 [Re: BDammers47]
Achipmunk Offline
Loc: Boiling Springs, S. C. 29316
Bill, is these what your using?
http://www.classicparts.com/1947-63-Window-Regulator-Rollers/productinfo/18-795/
If so here is MY experience with them so take it for what its worth.
When I put these new rollers in I found that when I ground off the back, and knocked the old ones out, that the hole that was left was to BIG for the new rollers stem. I then had "stems" specially made by a bolter friend to fit the hole in my regulator arm but still used the plastic rollers.
**what I should have done was grind the old stems flat and NOT punch them out. With them ground flat I could then center punch/mark the center and then drill a hole the size of the new ones I received...put the new ones in and then peened them a time or two to make sure they hold in place.
Hope all this makes sense?!
The current repops may now have the right diameter "stem" but I would not bet on it. If you have any questions maybe we could discuss it over some BBQ at Charlies or here at my shop. I have an extra one on hand.
Edited by Achipmunk (Fri Jan 11 2013 01:07 PM)
Edit Reason: clarification
Pictures in my Photobucket
Top
#910962 - Sat Jan 12 2013 01:41 AM Re: Window Regulator Roller Replacement - '47 3100 [Re: BDammers47]
MNSmith Offline
Loc: So Cal
New ones do fit pretty good. I did like you, grind the back then just wiggled out the remainder. I put the new one in, took a chisel and gently gave a whack to back side of the stem. Turned the chisel 90 degrees and gave another gentle whack. Everything seemed nice and tight. Time will tell!
Mark
1951 Chevy Suburban
Lots and LOTS of pictures
Top
#911195 - Sat Jan 12 2013 02:59 PM Re: Window Regulator Roller Replacement - '47 3100 [Re: BDammers47]
Achipmunk Offline
MNSmith,
Thanks, I'm glad to hear they are now correct. I have s couple of the rollers with the wrong size stem in them and an old regulator I was going to repair for a spare rather than through it away. When I do this I will try to remember to show a picture of my delema back when I put mine in....probably 2 years ago.
Thanks again.
Top
#911262 - Sun Jan 13 2013 01:05 AM Re: Window Regulator Roller Replacement - '47 3100 [Re: BDammers47]
Denny Graham Offline
Loc: Sandwich, IL
The original regulators did not use a roller, it was just a
stepped post the slid on the channel. One washer was inside the
channel and the other out side. The leather washers kept the
post in it's proper location in the channel, held the
lubrication and kept it from rattling.
http://www.pbase.com/dennygraham/1950_doors&page=all
To set the new posts I used a ball bearing and a hydralic press.
http://www.pbase.com/dennygraham/image/120007835
Denny Graham
Sandwich, IL
Top
#911278 - Sun Jan 13 2013 02:46 AM Re: Window Regulator Roller Replacement - '47 3100 [Re: BDammers47]
Achipmunk Offline
...Denny, well done and well said. I remember the leather washer discussion back when I did mine but for some reason I figured the plastic roller would be as good, maybe last a bit longer, than the leather. I'm happy with the rollers and my windows work great but it sure threw me when the repop stems were to small and I had already driven out the old studs.
..and a big thanks to you Denny for all the work you've done. I know a lot of bolters look at your work and I have certainly told my share of folks to check out your work to get answers.
Thank You.
Edited by Achipmunk (Sun Jan 13 2013 02:47 AM)
Edit Reason: speelllling
Top
#911308 - Sun Jan 13 2013 05:29 AM Re: Window Regulator Roller Replacement - '47 3100 [Re: BDammers47]
MNSmith Offline
Loc: So Cal
I second that, Denny!!
I'll have to look for my old studs to see if they were the originals.
Mark
1951 Chevy Suburban
Top
#911344 - Sun Jan 13 2013 07:02 AM Re: Window Regulator Roller Replacement - '47 3100 [Re: BDammers47]
Loc: Sandwich, IL
No one is reproducing the original style studs. The ones I show
in my album are ones that I made on a 6" Logan engine lathe I
had in the basement.
I looked into having a batch of true to original ones run off at
a local machine shop on a CNC turning center but the cost
to program it turned out to be to much for a short run. Besides
marketing them to recoupe the investment becomes a problem in
that we can't mention that we have them for sale in the most
popular forums like here, and the word gets lost in a day over
in the sparsely visited Swap Meet forum. I went thru that
exercise when I had a bunch of vinyl paint stencils made up for
the "Thrift Master" logos, still stuck with a bunch of those.
But if one is interested in having their windows roll up like
they did when the truck was new, an accurate reproduction of the
original parts can be made if you have access to a small bench
lathe. The dimensions for the posts and washers are posted in
my album.
Denny Graham
Sandwich, IL
Edited by Denny Graham (Sun Jan 13 2013 07:06 AM)
Top
#911469 - Sun Jan 13 2013 01:40 PM Re: Window Regulator Roller Replacement - '47 3100 [Re: BDammers47]
BDammers47 Offline
Loc: South Carolina
Alvin, Denny, and MN,
Thank you for your help. I'm less intimidated by this project now.
A Work in Progress
Top
#1034009 - Fri Jun 06 2014 10:17 PM Re: Window Regulator Roller Replacement - '47 3100 [Re: Achipmunk]
Ritchie 54 Offline
Loc: Bethesda, MD
Alvin
I got the same roller replacement kit from Classic. Before I jump into the deep end I want to confirm you are saying I need to grind off the "shiny" end cap of the current window roller. If I understand once I do that, I should leave the old sleeve in the regulator arm and insert the new wheel. Let me know if I am on the right path.
Window roller connection at regulator
Bob
1954 Chevy 3100 5-Window
1954 5-Window COE aka "THE BEAST"
Bill Ritchie's Original Truck
Granddad's Hardware Store: Ritchie Hardware, Concord, N.C.
Bethesda, MD
Top
Page 1 of 2 1 2 >
Moderator:  48bigtrucks
