The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Indianapolis Fabrications
Talk to Randy Domeck
See what they
can do
for you
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
12 registered (Cablesmill, Britcon, bluesman, Hotrod Lincoln, Hollow65, 1 invisible), 471 Guests and 4 Spiders online.
Forum Stats
39,744 Registered Members
48 Forums
106,218 Topics
Most users ever online: 940 @ Tue Apr 04 2017 09:52 PM
Today's Birthdays
aree, atruckdoc, CGG_64C10, ET, Jimmy B, michaelnshannon, newton54, Righty, salvo, Sarah, Village_Idiot
Image Posting Policy
New Reply
Topic Options
#890947 - Sun Oct 21 2012 03:38 AM Help Identifing rear diff
fiftee3 Offline
Loc: Somerset County, NJ
Hello, First post here. Have a 53. Here is a pic of the rear which I cant seem to identify. Has two bumps at 11:00 and 7:00 on rear cover. Can't find numbers on it. From what I've read, its an open rear so it cant be original, correct?
Here are the photos...
http://fiftee6.com/fiftee6_015.htm
Thanks, Phil
Top
#890958 - Sun Oct 21 2012 04:44 AM Re: Help Identifing rear diff [Re: fiftee3]
tclederman Offline
Loc: Jarvisburg, NC
Phil,
A 1953 car and a 1953 1/2 ton truck would have had an enclosed driveshaft.
Larger 1953 trucks would have had an open rear end.
Maybe someone can ID what you have from that photo. Post any codes on the body of the rear end and maybe someone can help with those?
Top
#890959 - Sun Oct 21 2012 04:47 AM Re: Help Identifing rear diff [Re: fiftee3]
Kurt_51carryall Offline
Loc: Raleigh,NC
Phil,
Is this a 1/2 ton or 3/4 ton? If 3/4 ton with the 8 lug wheels, It will be open drive shaft.
Kurt
Top
#890962 - Sun Oct 21 2012 04:50 AM Re: Help Identifing rear diff [Re: fiftee3]
fiftee3 Offline
it is 1/2 ton/3100. But maybe this is out of a 3/4 and changed to 6 lug? I'm just trying to figure out what year and what 10 bolt it is. Was also trying to figure ratio, but I guess I'll have to pull the cover and count teeth. Its leaking anyway!
_________________________
Phil
www.fiftee6.com
http://fiftee6.com/fiftee6_016.htm. (this is my pickup)
Top
#890964 - Sun Oct 21 2012 04:51 AM Re: Help Identifing rear diff [Re: fiftee3]
fiftee3 Offline
Can't seem to find codes either?
Phil
www.fiftee6.com
Top
#891013 - Sun Oct 21 2012 09:25 AM Re: Help Identifing rear diff [Re: fiftee3]
LONGBOX55 Offline
Loc: DANVILLE IL
It's a '55-'62 HO33 from a 1/2 ton truck. There should be a code stamped on the passenger side of the 3rd member. That code will give the ratio, though most likely it will be a 3.90.
Bill Burmeister
Top
#891058 - Sun Oct 21 2012 01:42 PM Re: Help Identifing rear diff [Re: fiftee3]
fiftee3 Offline
Thanks Bill,
Found numbers / 3707340 D2 Is this 3:90,s or 3:70,s?
And if 3:90,s what will be top speed on the 216 and max rpms approx.? Sorry, this dipper engine thing is all new to me! I met a guy at a carshow Saturday and he has a 235 from a 57 he'd let go for 300.00. But I actualy like the 216 now that I have it running!
Phil...
Top
#891061 - Sun Oct 21 2012 01:54 PM Re: Help Identifing rear diff [Re: fiftee3]
Flxible Offline
Boltergeist
Loc: north of the 49th
there was no 3.70, the standard was 3.90 with an optional 4.11 .... if you want the engine to last a long time, it'd be "comfortable" at 2500 and a max of 3000, and don't expect to be cruising at more than 55, especially with stock brakes
Top
Moderator:  SWEET
