The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
36 registered (1953 panel, 40_chevy, 2ton46, '54 3600, 2-Ton, 3B, 2 invisible), 570 Guests and 4 Spiders online.
Forum Stats
39,407 Registered Members
48 Forums
105,407 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
19chevy38, BF Finster, BigBambino22, crcmk7w, dmtexas, jay smith, Jim Williams 7w, Kevin W. Johnson, Noe_swede, pablos49
Image Posting Policy
Page 2 of 3 < 1 2 3 >
New Reply
Topic Options
#887061 - Fri Oct 05 2012 04:54 AM Re: clutch head bolt removal [Re: BLUEMEANIE]
Kurt_51carryall Offline
Loc: Raleigh,NC
Yeah, the right size bit is critical. I got a nice set a few years ago, for the most part they fit snug, sometimes I have to tap them into the screw head.
Kurt
Top
#887078 - Fri Oct 05 2012 06:05 AM Re: clutch head bolt removal [Re: Kurt_51carryall]
johntsmith Offline
Loc: Tampa Bay FL
When I strip out a clutch head I take a cutting wheel in my dremmel and CAREFULLY cut a slot into the top of the screw and then use a flat bladed screw driver. Same for rounded bolt heads and stripped phillip heads. Make sure your slot and blade are a snug fit.
In our garage we have a rule that clutch head screws can only be turned counter clock wise!
Edited by johntsmith (Fri Oct 05 2012 06:07 AM)
_________________________
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Top
#887087 - Fri Oct 05 2012 06:27 AM Re: clutch head bolt removal [Re: Midpiner]
Loc: Raleigh,NC
I still have most of my original clutch head screws/bolts, but I am missing a few, (such as one of the screws that holds on the voltage regulator) I hope you guys that are replacing them might consider dropping any good ones in an envelope and mailing them to me......
Kurt
Top
#887157 - Fri Oct 05 2012 10:55 AM Re: clutch head bolt removal [Re: Midpiner]
cletis Offline
Loc: Parker County Texas
I find that using a scribe to clean the clutch head socket first helps. I also try to tighten the screw first to break the rust. As mentioned above, penetrating oil helps. In stubborn cases I heat them. I rarely need to drill one out. Of course I realize the climate a truck spent its life in may have some bearing on the ease of dis-assembly.
1954 GMC Suburban
My TRUCKS website
Top
#887189 - Fri Oct 05 2012 01:03 PM Re: clutch head bolt removal [Re: Kurt_51carryall]
BLUEMEANIE Offline
Loc: St.L MO
You got it! PM me your mailing address. I'll set aside all the good ones for ya.
1951 Chevy 3100
www.rustyfiftyone.com
Top
#887199 - Fri Oct 05 2012 01:48 PM Re: clutch head bolt removal [Re: Midpiner]
bartamos Offline
Loc: The Ranch
If those would have been Phillips heads, long ago, and rusted in place, as they did, the head would have stripped easier than clutch. The "Phillips", actually called cross recess, is probably the worst head to remove when rusted. We have all become accustom to Phillips and they are widely available. The aerospace industry tried to get rid if the cross recessed head because it is just about the only head that needs downward force to tighten and loosen. All the rest just need torque and don't "wind" out like Phillips. We could not change over because there were so many out there already and not all service centers, repair facilities and etc would have a torx or allen or square or clutch or star or whatever was decided to be the new head..... and slotted is not driver retaining. The good side of cross recessed is that it stays on the driver fairly well for assemblers, they do ok in low torque requirements and it's configuration allows for a stronger screw head, especially flathead. A new/cleaned clutch head screw with proper driver works very well and ORIGINAL!
1960 GMC K10 Shortbed Wideside BBW CC BBV6 (The Oreo SpeedWagon)
If you can't fix it with a hammer, you have an electrical problem.
Top
#887206 - Fri Oct 05 2012 02:07 PM Re: clutch head bolt removal [Re: Midpiner]
BIG CHEVY 3600 Offline
Loc: DALLAS/BLANCO TEXAS
Stainless with anti-cease is the best way to go unless you're into the original show condition.
Jim
Big Chevy's Photobucket pix
FIRST START http://www.youtube.com/watch?v=Fb-4nPArk98
Modern ‘science’: the wonder of a
pre-determined mind…
The ‘baseline belief’ of astronomy:
“Any day now, we’ll pick up a tiny,
coded signal from outer space. Then
we’ll know for certain that there is
intelligence out there, because coded
information does not arise by chance”
The ‘baseline belief’ of biology:
The precisely coded genetic information in
every cell would fill many books…
but we know for certain that no intelligence
could have created life.”
Top
#887249 - Fri Oct 05 2012 04:05 PM Re: clutch head bolt removal [Re: Midpiner]
tclederman Online
Loc: Jarvisburg, NC
The clutch head bolts were far superior to other bolt/screw heads. As stated above, any-headed bolt is a pain when rusted.
http://1954advance-design.com/Web%20images/clutch-head-1.jpg
Kurt, PM me what clutch head bolts/screws you need. Another stovebolter sent me all of his. If I have extras, I'll "pay it forward" to you.
Top
#887260 - Fri Oct 05 2012 06:02 PM Re: clutch head bolt removal [Re: Midpiner]
bartamos Offline
Loc: The Ranch
Bluemeanie and Tclederman: Sometimes I need reminded, That's what this site is all about. Good job boys.
Top
#887419 - Sat Oct 06 2012 01:43 PM Re: clutch head bolt removal [Re: Midpiner]
Midpiner Offline
Loc: Escalon Ca.
Thanks for all the replys.Will try the impact on the other side.
Top
Moderator:  cletis
