The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
36 registered (1962C10, 3800rao, 1953 panel, 49nut, 3 invisible), 364 Guests and 10 Spiders online.
Forum Stats
39,539 Registered Members
48 Forums
105,776 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
briang, emerson, finally have one, levi_69, paul stewart, Wild Turkey
Image Posting Policy
Page 2 of 2 < 1 2
New Reply
Topic Options
#882078 - Tue Sep 11 2012 10:18 PM Re: Corner windows one more time! [Re: truckernix]
jockbolter50 Offline
Loc: Scotland
Originally Posted By truckernix
Somewhere before half way around the thing becomes very unstable and wants to pop out. Once you get past half way it get a little easier.
True,the secret is not to make everything too slick,sometimes too much lubrication(soap) makes it like juggling jello!
Hence the reason I prefer good old fashioned glass cleaner.
_________________________
More pix on Flickr .
Top
#882090 - Wed Sep 12 2012 03:20 AM Re: Corner windows one more time! [Re: jockbolter50]
54barnfind Offline
Loc: Indianapolis, Indiana
Here is another slide show on corner glass
....David
Top
#882732 - Fri Sep 14 2012 05:42 PM Re: Corner windows one more time! [Re: 54barnfind]
Peter_H Offline
Loc: Burlington, ON, Canada
Thanks for all replies.
I tried putting the rubber in the opening first with ones that I had bought from JC but, the rubber was too stiff and was impossible to fit so we gave up the notion in frustration.
We ordered another set from Steele Rubber and it was much better although we ruined that set trying to once again fit the glass into the opening.
After reading this and many other threads and talking to Steele Rubber I have decided to put the new set of rubbers on the glass for a week or so to climatize and then fit them in the opening. Steele suggesting leaving a little slack and then gluing the two ends together. This is consistent with the methods suggested for the other windows in the truck.
If it is still warm enough here this year when I get the new rubbers I will try it and report back.
This is quickly becoming one of the most challenging tasks of my rebuild - one that I thought would be easy peasy. How on earth did they ever do this on an assembly line??
Thanks for all your suggestions.
1951 Chevy 3100 5-Window
"Howard"
More pix on Photobucket
Top
#882758 - Fri Sep 14 2012 10:43 PM Re: Corner windows one more time! [Re: Peter_H]
Loc: Scotland
Sorry to hear of your tales of woe Peter,but on your production line comment.
If you're doing the same job day in,day out,it soon becomes second nature....
This is probably little consolation but...practice makes perfect!
Good luck.
Top
#882873 - Sat Sep 15 2012 10:22 AM Re: Corner windows one more time! [Re: jockbolter50]
CASO Offline
Loc: Warrenton, Oregon
Originally Posted By jockbolter50
[quote=Peter_H]Thanks for all replies.
Good luck. [/quote]
So is that a suggestion he grab a practice piece and trash it till he gets it down and then try with a new one? eeeek
Give me ambiguity
or give me something else
Top
#882974 - Sat Sep 15 2012 11:13 PM Re: Corner windows one more time! [Re: CASO]
Loc: Scotland
From what I can gather Peter's already had his 'practice' shot!
Top
#882975 - Sat Sep 15 2012 11:20 PM Re: Corner windows one more time! [Re: jockbolter50]
Loc: Scotland
The biggest causes of the rubber gauling or tearing is usually down to the glass edge being poorly finished,lack of 'lubrication' or poor quality rubber.
The main trick is to use the edge of the glass as a lever point keeping the plastic stick to as near 90 degrees to the glass and roll the lip over the glass using a twisting motion like this.
Edited by jockbolter50 (Sat Sep 15 2012 11:27 PM)
Top
#883161 - Sun Sep 16 2012 05:32 PM Re: Corner windows one more time! [Re: jockbolter50]
Peter_H Offline
Yes, I have had my practice run! And yes, I did trash a good set of rubbers.
My question about how they did this on the assembly line should have been worded more clearly.
Did they put the rubber on the cab and then install the glass or put the rubber on the glass and then install it as unit?
I am still not sure.
If nothing else, Steele Rubber thinks I am wonderful :-)
"Howard"
Top
#883193 - Sun Sep 16 2012 09:20 PM Re: Corner windows one more time! [Re: Peter_H]
Loc: Scotland
Peter,i'm not entirely sure how it was done in the factory,but the way I was trained to do it was to fit the rubber to the body,then work the glass into it,then install the lock strip.
As I've said in many related threads,the section of the rear rubbers is in the form of an 'H' this usually dictates the installation technique mentioned above.
If however the rubber is an 'S' section (such as the front windshields) that would normally be installed using the cord/rope method with the rubber on the glass.
I hope this clears up any confusion,and as previously mentioned...good luck.
Hopefully you won't be qualifying for a Steeles bulk order discount! wink
Top
Page 2 of 2 < 1 2
Moderator:  Fourbrads, HandyAndy1947
