The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
33 registered (Allen Lane, ASU, 1953 panel, 48bigtrucks, 66flea, 1 invisible), 636 Guests and 4 Spiders online.
Forum Stats
39,525 Registered Members
48 Forums
105,724 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
1956Chevy3100, akguy34, BobS46, mmillard, newowner, oldschoolauto, _Dragon_
Image Posting Policy
New Reply
Topic Options
#877591 - Sat Aug 25 2012 11:21 AM Fuel gauge reading backwards?? HELP!
loadmaster235 Offline
Loc: Athens GA
49 GMC 1 ton
Converting to 12 v
235 6 cyl
Original fuel gauge and sending unit
Running power through a resistor.
Okay you wizards of all things old trucks- I need your help! I recently tested my fuel tank sending unit and my fuel gauge to make sure they both worked before I install them in the truck. As info, I did check the sending unit,which came out of a 49 GMC 1 ton. It "ohmed" as you would expect throughout the full range of motion. They were hooked up as follows:
The sending unit was hooked up directly to the hot side on the fuel gauge. Power came directly from a 12v battery through a voltage reducer, to the power side of the fuel gauge, the ground wire came off the battery to the ground connection on the sending unit and also grounded to the back of the shell of the instrument cluster. Please note, I read every entry I could find in the tech tips section of the forum regarding the correct way to hook up a fuel gauge and sending unit. I certainly did not want to ruin either my sending unit or fuel gauge by hooking them up backwards.
Here's the problem, when everything is connected, and the sending unit is resting on empty, the fuel gauge is sitting in about one quarter full. However when I activate the sending unit to read a full tank,the fuel gauge needle actually moves toward the empty side of the gauge. In other words, the fuel gauge seems to be operating backwards! Please help an ol boy figure out what's wrong.
Thanks in advance
Edited by loadmaster235 (Sat Aug 25 2012 11:24 AM)
Top
#877593 - Sat Aug 25 2012 11:39 AM Re: Fuel gauge reading backwards?? HELP! [Re: loadmaster235]
Flxible Offline
Boltergeist
Loc: north of the 49th
just reverse your connections at the gauge, won't hurt anything and will no doubt read correctly .... the sender hooks to the ground side of the gauge, the battery hooks to the "hot" side .... if the gauge is inaccurate you can just live with it, knowing what the gauge says when the tank is actually empty, or you can try bending the needle
_________________________
Top
#877604 - Sat Aug 25 2012 12:55 PM Re: Fuel gauge reading backwards?? HELP! [Re: Flxible]
Loc: Athens GA
Thanks. Question. I thought of reversing the terminals at the gauge, but that red tag on the back says hooking the power to the wrong post will ruin the sender unit?
Top
#877678 - Sat Aug 25 2012 03:30 PM Re: Fuel gauge reading backwards?? HELP! [Re: loadmaster235]
Flxible Offline
Boltergeist
"The sending unit was hooked up directly to the hot side on the fuel gauge. Power came directly from a 12v battery through a voltage reducer, to the power side of the fuel gauge"
again, the sender provides the ground that makes the gauge work, it is not/can't be hooked to the "hot" side, which is what would be the battery or positive side - the only way the sender would be damaged is maybe if you run a full 12V thru it to ground it might fry the resistance in it - when testing just don't make 'permanent' connections, have the battery + wire in hand and just touch it to the post to watch the reaction
what are you calling the "ground connection on the sending unit"? the sender is grounded by it's mounting flange screws, the wire terminal on the sender is the wire to the gauge .... the circuit is >
battery + to the + terminal on the gauge;
battery - to the gauge case and sender case;
sender terminal to the 2nd terminal on the gauge
someone else might have a better idea of why a gauge would work backwards, but to me if it reads backward, the wires are on backward
Top
#878818 - Wed Aug 29 2012 11:17 AM Re: Fuel gauge reading backwards?? HELP! [Re: Flxible]
k10 Offline
Loc: NH
GMC = positive ground. You are now running a neg. ground. Fix it fast or blow it up forever.
Top
#879682 - Sun Sep 02 2012 05:36 AM Re: Fuel gauge reading backwards?? HELP! [Re: k10]
sps Offline
Loc: joppa , maryland
Thats what I thought, GMC was a positive ground. Might try soldering the send wire on the other side of the resistor of the send unit, just a thought.
Top
#879728 - Sun Sep 02 2012 10:02 AM Re: Fuel gauge reading backwards?? HELP! [Re: sps]
bartamos Offline
Loc: The Ranch
Also always run a short wire from one of the sender mounting screws to a bare frame point. Many tanks are isolated from ground due to strap pads and rubber hoses. The factory TF assy manual shows a ground connection as I described. Just scribble out the F and put E and scribble out the E and put F. Just kidding.
1960 GMC K10 Shortbed Wideside BBW CC BBV6 (The Oreo SpeedWagon)
If you can't fix it with a hammer, you have an electrical problem.
Top
Moderator:  Rusty Rod
