The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Indianapolis Fabrications
Talk to Randy Domeck
See what they
can do
for you
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
6 registered (Cablesmill, Skip68, Britcon, wolffcub, muddytrck18, 1 invisible), 460 Guests and 4 Spiders online.
Forum Stats
39,744 Registered Members
48 Forums
106,218 Topics
Most users ever online: 940 @ Tue Apr 04 2017 09:52 PM
Today's Birthdays
aree, atruckdoc, CGG_64C10, ET, Jimmy B, michaelnshannon, newton54, Righty, salvo, Sarah, Village_Idiot
Image Posting Policy
New Reply
Topic Options
#875116 - Wed Aug 15 2012 06:31 PM 51-53 Chevy Rear Spring Seat Bushing
47bolter Offline
Loc: Oregon
So I picked up a 51-53 Chevy half ton rear axle housing to swap my 47 AD to bendix brakes. I have the housing just about de-rusted and ready to paint, but I'm having a heck of a time trying to get the bolt out that holds the spring seat and metal bushing in place. I looked at buying the new spring seat bushing from Chevs of the 40s and it comes with a new bolt and nut. Does that nut replace the apparently welded on 15/16th nut there now? And would it be a good idea to just cut the nut off the mount for the spring hanger? I don't want to just start cutting and accidentally ruin the mount.
Top
#875148 - Thu Aug 16 2012 01:28 AM Re: 51-53 Chevy Rear Spring Seat Bushing [Re: 47bolter]
truckernix Offline
Loc: Bracebridge Ontario Canada
What is the part number from Chevs of the 40s. I didn't know that they sold them.
_________________________
1951 1 Ton Completed
Top
#875151 - Thu Aug 16 2012 02:21 AM Re: 51-53 Chevy Rear Spring Seat Bushing [Re: truckernix]
tclederman Offline
Loc: Jarvisburg, NC
Probably this part/bolt? This part/bolt has been recently discussed. It is not exactly like the original but is easier to install (and it works fine).
Does your old part not have a nut on one end?
You might have to use a press to get the old bolt out. And, you will have to clean the old rubber out of the housing. freeze the new part/bolt and press it into the housing.
If I am describing the wrong part, let me know and I will delete this post.
By the way, is the 47 torque-tube the same length as the later torque-tube? I think that one of the transmission lengths changed after the 47 model year?
Top
#875158 - Thu Aug 16 2012 03:42 AM Re: 51-53 Chevy Rear Spring Seat Bushing [Re: tclederman]
truckernix Offline
Thank you. Was there a thread a while ago discussing whether the original had the steel on the outside?
Top
#875165 - Thu Aug 16 2012 04:18 AM Re: 51-53 Chevy Rear Spring Seat Bushing [Re: truckernix]
tclederman Offline
Loc: Jarvisburg, NC
http://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=832036#Post832036
i have used that part succesfully on two 1954 1/2 ton trucks.
Top
#875209 - Thu Aug 16 2012 07:31 AM Re: 51-53 Chevy Rear Spring Seat Bushing [Re: tclederman]
47bolter Offline
Loc: Oregon
Yup thats the one. It does have a 15/16th nut on one side, but you can see where it is welded to the bracket on the axle so I guess I'll carefully be cutting it off. I don't know if the floor shift 3 speed changed the length of the torque tube, but I just bought the housing and not a new third or torque tube. I was just going to bolt the old stuff up to the new axle housing. One more question. Are the seat mounts actually suppose to move in the bracket or are they suppose to be keyed in to roughly 90 degrees in relationship to the bracket? The ones on the new axle don't move and I doubt that when I remove the axle in my 47 that they will be inclined to move either. Thanks for all the advice there sure are a lot of ins and outs working on this old truck.
Top
Moderator:  SWEET
