The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
5 registered (TPR57C, tomctomc, Mickey3100, Organbuilder, greenie-reddy), 523 Guests and 4 Spiders online.
Forum Stats
39,527 Registered Members
48 Forums
105,745 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
17dave, dhckdkcsk, Jered, Paul's53chevy, {-_-}
Image Posting Policy
New Reply
Topic Options
#860567 - Wed Jun 20 2012 12:42 AM Auto Choke carb
Spotbiltxo Offline
Loc: San Antonio, Texas, USA
Picked up a Rochester single barrel carb with an auto choke on it at a swap meet. Can I use it on my 216 to replace the original Rochester B? I'm sure there's an adapter to be able to run the choke tube to the manifold, right?
Thanks!
_________________________
Chuck
1950 Chevy 1/2 ton
1951 Chevy 1/2 ton
1941 Chevy coupe
1938 Chevy coupe streetrod
Top
#860569 - Wed Jun 20 2012 01:05 AM Re: Auto Choke carb [Re: Spotbiltxo]
Hotrod Lincoln Offline
Loc: Dellrose, TN
As long as the stud spacing is right it will bolt on. Whether it's jetted right or not will be a crapshoot. Check out aftermarket "choke stove" listings to pick up manifold heat. The exhaust gas doesn't go to the carb, just air heated by passing over, or sometimes through the exhaust manifold.
I've seen an add-on heat exchanger that clamps onto the manifold with a couple of screw-type hose clamps, and a tube that routes the hot air to the choke housing. Simply wrapping a piece of copper tubing around the manifold a few turns and securing it with a couple of clamps also works.
"It is better to be feared than loved, if one cannot be both"
Machiavelli
"He ain't even got a noddin' acquaintance with the truth- - -let alone a speakin' one!"
Top
#860765 - Wed Jun 20 2012 06:38 PM Re: Auto Choke carb [Re: Spotbiltxo]
tclederman Offline
Loc: Jarvisburg, NC
This universal choke stove kit might work on a Rochester BC carburetor.
Top
#860798 - Wed Jun 20 2012 09:20 PM Re: Auto Choke carb [Re: tclederman]
Spotbiltxo Offline
Thanks Jerry and Tim. I guess it's a crap shoot if it will work since I still don't know if this specific Rochester carb was ever intended to be used on a 216, but it's worth a try I guess.
Thanks again.
Chuck
1950 Chevy 1/2 ton
1951 Chevy 1/2 ton
1941 Chevy coupe
Top
#860824 - Wed Jun 20 2012 10:47 PM Re: Auto Choke carb [Re: Spotbiltxo]
Loc: Dellrose, TN
If it's jetted for a 235, it will run lean on a 216. There's not enough venturi velocity to develop sufficient vacuum to pull enough fuel through the main jet. A bigger jet and/or a higher float level will help, but it's a balancing act on the float level between high enough to flow fuel, and a tiny bit higher that causes flooding. There's also a danger of keeping the power valve open all the time due to low manifold vacuum, which will result in lousy fuel mileage!
Machiavelli
Top
#860834 - Wed Jun 20 2012 11:22 PM Re: Auto Choke carb [Re: Hotrod Lincoln]
Spotbiltxo Offline
Okay Jerry........a dumb question. If the stud spacing is right and it bolts on can I assume it is for a 216 and therefore might be correctly jetted? Or were there different stud spacings for the 235's?
Chuck
1950 Chevy 1/2 ton
1951 Chevy 1/2 ton
1941 Chevy coupe
Top
#860856 - Thu Jun 21 2012 12:28 AM Re: Auto Choke carb [Re: Spotbiltxo]
tclederman Offline
Loc: Jarvisburg, NC
Yes, it looks like there were two passenger carbs with automatic choke. One was for 50-52 Powerglide equipped cars, which would have had a 235 and the wider stud spacing. The other (7005060) was for 37-52 cars and would have been for a 216, with the smaller stud spacing. 1954 and later BC carbs would have been for 235 engines, all with the wider stud spacing.
I am not going to guess about 1953 non-Powerglide car engines and carbs' stud spacing.
http://chevy.oldcarmanualproject.com/1929_54chevyparts/03/200.HTM
Top
#860866 - Thu Jun 21 2012 02:00 AM Re: Auto Choke carb [Re: tclederman]
Spotbiltxo Offline
Tim, So our trucks never came equipped with carbs with automatic chokes? If not then it's safe to say that this carb I have probably won't run right on my 216.
Oh well............
Thanks very much.
Chuck
1950 Chevy 1/2 ton
1951 Chevy 1/2 ton
1941 Chevy coupe
Top
#860894 - Thu Jun 21 2012 08:25 AM Re: Auto Choke carb [Re: Spotbiltxo]
tclederman Offline
Loc: Jarvisburg, NC
If its a 216 carb, it might work OK. Changing a carb in and out is not a difficult or tricky job, give it a try. If you have not rebuilt the carb, your biggest gamble is if it in working condition.
Top
#861328 - Fri Jun 22 2012 10:00 PM Re: Auto Choke carb [Re: tclederman]
Kurt_51carryall Offline
Loc: Raleigh,NC
The 1953 non-powerglide car also had a 235 engine with auto choke, but had solid lifters.
Your truck should run fine with the automatic choke carb if it is for a 216. I ran my 235 powerglide engine for quite a few years with the auto choke before I found a good manual choke carb.
It's just so much more fun to work the choke and throttle, which is why I switched.
Kurt
Top
Moderator:  53moneypit, Woogeroo
