The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
3 registered (jacksont, Super55, 1 invisible), 433 Guests and 5 Spiders online.
Forum Stats
39,267 Registered Members
48 Forums
104,774 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
1 Dollar, aerotruk63, GTA Scott, mb53, Norman Meloche, pauldumont, rscott, steven simpson, thor
Image Posting Policy
New Reply
Topic Options
#848733 - Thu May 03 2012 09:19 PM Help wiring for Eaton 2 speed axle
GMCPic Offline
Loc: Paradise,CA,USA
Any and All,
I need to replace the shifter switch for my 454-30 dump truck. Switch is broken and crumbling.
I found a new switch on eBay, but no wiring diagram. Wires are in 3 different sections/pieces none of which are connected.
Anyone have the diagram to wire up a electric shift 2 speed. Circa 1952.
Thanx, wink
GMCPic
_________________________
Dance like no one is watching,
Sing like no one is listening,
Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420
1948 GMC FC253 1t Factory 80"x9' Flatbed Dually
1948 Chevy COE 2 Ton 8'x15' Flatbed
1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton Cab and Chassis
1942 Clarkator 6 MILL-44 Heavy Aircraft Tug
1942 Ford (9N) Moto Tug with 1/2 yard Loader
1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
Top
#848764 - Thu May 03 2012 10:23 PM Re: Help wiring for Eaton 2 speed axle [Re: GMCPic]
Mike B Offline
Loc: Hughesville, MD
GMCPix,
I assume you have the Red push/pull switch...
The switch is wired as follows;
Green = 12v from the Fuse Panel
Red = High Rear
Black = Low Rear
The Black wire will be Tee taped under the floor with a wire that goes up to the speedometer adaptor located at the dash. The adaptor keeps the speedometer accurate regardless of what speed the rear is in, it's a little electric reduction unit in-line with the speedometer cable.
Make sure you ground both the electric shift motor and the adaptor...
That's it!
Mike B smile
Edited by Mike B (Thu May 03 2012 10:24 PM)
Top
#869023 - Tue Jul 24 2012 01:03 AM Re: Help wiring for Eaton 2 speed axle [Re: Mike B]
GMCPic Offline
Got bigger problems now with shift unit.
When I hookup the switch and turn on key/power I get power to both terminals. Even when I disconnect one wire from switch terminal block.
Wires are totally rotten, crumble when touched.
So now I have to rewire the whole shift system.
Also, I am going to look into changing the shift motor too 12v.
Any ideas?
Top
#869260 - Tue Jul 24 2012 08:48 PM Re: Help wiring for Eaton 2 speed axle [Re: GMCPic]
Mike B Offline
GMCPic,
The switch and switch harness are still available new from Eaton. The switch is part number 32861 (about $10), I can't find the harness number. I think I got one from NAPA about a year ago.
The center terminal on the switch gets the hot wire from the fuse block. The top terminal is High speed and the bottom is Low.
Mike B smile
Top
#869274 - Tue Jul 24 2012 10:15 PM Re: Help wiring for Eaton 2 speed axle [Re: Mike B]
GMCPic Offline
Found some parts on ebay for old style Eaton 2 speed.
Now I have to find out if they will work.
Also I found another truck on Craig's list.
Going to look at it Sat.
Top
Moderator:  69Cuda, Grigg
