The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Spring is here!
If you are bringing the old truck out of winter storage, or up from the woods, be sure to check the Tech Tip for a few helpful hints.
If you have some work to do before you go cruising, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
33 registered (49 3100, 54CarryAll, BBPanel, 46forme, 3 invisible), 601 Guests and 4 Spiders online.
Forum Stats
39,641 Registered Members
48 Forums
105,719 Topics
Most users ever online: 940 @ Tue Apr 04 2017 09:52 PM
Today's Birthdays
jesi, jonflores, Kens 50 PU, Zulu Pete
Image Posting Policy
Page 2 of 2 < 1 2
New Reply
Topic Options
#705830 - Thu Dec 23 2010 08:06 AM Re: AC glass top fuel pump rebuild? [Re: yar]
Grigg Online
Loc: Lexington, VA
A little hooked puller widget might yank the one on he right out.
The one on the left, if it seals any, might come out by over pressurizing with a grease gun, might also split the housing...
Drilling and threading a small slide hammer in sounds like a good idea too.
Grigg
_________________________
1952 Chevrolet 3800 pickup
---All pictures---
Top
#705882 - Thu Dec 23 2010 01:12 PM Re: AC glass top fuel pump rebuild? [Re: Grigg]
Denny Graham Offline
Loc: Sandwich, IL
Sheet metal screw in the small slide hammer worked like a charm, took less than a minute to pop them out with absolutely no damage what so ever to the casting. Only way to go.
DG
Top
#843161 - Wed Apr 11 2012 05:59 PM Re: AC glass top fuel pump rebuild? [Re: Denny Graham]
801curt Offline
Loc: Salt Lake City, Utah
Here is a picture of my glass top fuel pump from my '48 1.5 ton. Before I destroy my old valves I want to make sure that these new ones (in the picture) will work on my pump. The kit I purchased is from Jim Carter.
I appreciate all input, Thanks
Curt Warren
Salt Lake City
1948 1.5ton Loadmaster
http://photobucket.com/48loadmaster
Top
#843280 - Thu Apr 12 2012 08:18 AM Re: AC glass top fuel pump rebuild? [Re: 801curt]
don stocker Offline
Loc: osceola, wi
I did as Denny mentions with the sheet metal screw. Worked perfect. I've done this a few times.
Top
#843319 - Thu Apr 12 2012 11:52 AM Re: AC glass top fuel pump rebuild? [Re: don stocker]
801curt Offline
Don is this what you would consider a 'small slide hammer'?
Do you see any problems with the new valves ? Though they have a different style top/bottom the size and functionality seems the same to me.
Curt Warren
Salt Lake City
Top
#843325 - Thu Apr 12 2012 12:17 PM Re: AC glass top fuel pump rebuild? [Re: 801curt]
rustednuts Offline
Loc: Kingston, WA
I used a cotter pin puller on mine and popped them out. It didn't mar the pump top.
As long as the valves are the same size, they should work. Mine were different types but the size was the same.
Other AC pumps I've taken apart had a small hourglass piece of thin metal placed between the valves to hold them in place and attached directly between the valves with a small screw.
Jeff
Hey guys, hows the weather? grin
Lifes to short to worry about how short life is.
1951 Oldsmobile Super 88 w/303 and hydramatic
My 1953 Chevrolet
1947.1 GMC Art Deco COE / 1947.1 Gallery
Top
#843892 - Sat Apr 14 2012 09:16 PM Re: AC glass top fuel pump rebuild? [Re: rustednuts]
801curt Offline
Thanks Jeff, I picked up a cotter pin puller today, tomorrow I hope to remove the old ones.
Curt Warren
Salt Lake City
Top
#843954 - Sun Apr 15 2012 07:54 AM Re: AC glass top fuel pump rebuild? [Re: 801curt]
don stocker Offline
Loc: osceola, wi
I have also used a vice grip on the screw and then a small piece of wood to pry against. They come out pretty easy. The replacements usually look different but work just fine.
Top
#844276 - Mon Apr 16 2012 02:04 PM Re: AC glass top fuel pump rebuild? [Re: 801curt]
801curt Offline
The old ones were not to difficult to remove. The 'star face' broke off of one, but otherwise it was straight forward. Thanks again!
Curt Warren
Salt Lake City
Top
Page 2 of 2 < 1 2
Moderator:  53moneypit, Woogeroo
