The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
60 registered (5 Window 9434, 49nut, 3B, 48bigtrucks, 1953 panel, 3 invisible), 690 Guests and 5 Spiders online.
Forum Stats
39,515 Registered Members
48 Forums
105,692 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
40_chevy, bigfoot, chevy1938, Chief36chevy, james b., jots, K-FLY, lightfoot, ruhere, White Elephant
Image Posting Policy
New Reply
Topic Options
#838886 - Mon Mar 26 2012 05:41 PM 235 Intake Manifold
fab51 Offline
Loc: Central Missouri
So, I'm probably overthinking things again...
Not too long ago, I picked up an Offenhauser dual carb intake, and was planning on using dual Carter YF's. After playing around with things recently, I've found that I don't have a good matched set of carbs. So, I've been wondering...
Did anyone ever produce an aluminum single carb intake, that would have better flow characteristics than the stock intake?
Which stock intake is better? I have a truck intake with the tall center section, but I also have a car intake with the short center section. Which one flows better?
I've about talked myself into staying with one, well tuned Carter YF. I just want to know which manifold will perform the best.
TIA thumbs_up
_________________________
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam & Split Manifold
Top
#838917 - Mon Mar 26 2012 07:37 PM Re: 235 Intake Manifold [Re: fab51]
Pre '68 Dave Online
Loc: Snohomish,WA,USA
The difference in short and tall intake is not car v truck. The parts book shows pass and truck using the same intake. The tall was used up through 1958, then because the hood was lowered on the car line in 1959 the shorter intake was used.
As far as which flows better I doubt there is much difference although the rated HP went up in the later years. That most likely had nothing to do with the intake.
Both manifolds take a difference length throttle rod.
My Blog
Top
#839172 - Tue Mar 27 2012 05:48 PM Re: 235 Intake Manifold [Re: Pre '68 Dave]
fab51 Offline
Too bad...I was kinda hoping I had something special. ohwell
-Tim
Top
#839197 - Tue Mar 27 2012 07:17 PM Re: 235 Intake Manifold [Re: fab51]
mark50 Offline
Loc: San Francisco CA
I'm pretty sure Nicson made an aluminum single carb manifold. Did it flow better than a stock version? I have no idea. There was one on eBay a couple of months ago. I'm guessing it's rarer than their more common 2 x 1 manifolds as most guys installing an aftermarket manifold were looking for horsepower gains.
Top
Moderator:  53moneypit, Woogeroo
