The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Indianapolis Fabrications
Talk to Randy Domeck
See what they
can do
for you
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
47 registered (55 SHAKER, 66flea, 52Carl, Allen Lane, 4 invisible), 636 Guests and 4 Spiders online.
Forum Stats
39,736 Registered Members
48 Forums
106,167 Topics
Most users ever online: 940 @ Tue Apr 04 2017 09:52 PM
Today's Birthdays
52 pick-up, coppertinman, daviper1996, deimos540, Mr. Pickett, Rick In VA
Image Posting Policy
Page 1 of 3 1 2 3 >
New Reply
Topic Options
#837288 - Wed Mar 21 2012 10:49 AM Wheel Bearing Opinions
NathanPlemons Offline
Loc: KY
I have seen that several sites now seem to offer new style roller bearings instead of the old style ball bearings. They cost more, is there any real practical benefit?
Top
#837299 - Wed Mar 21 2012 11:07 AM Re: Wheel Bearing Opinions [Re: NathanPlemons]
Flxible Offline
Boltergeist
Loc: north of the 49th
not unless you want to switch to disc brakes, you may even find the bearings on yours are the ones it came from the factory with
_________________________
Top
#837344 - Wed Mar 21 2012 02:30 PM Re: Wheel Bearing Opinions [Re: Flxible]
Wrenchbender Ret. Offline
Loc: Lenexa Ks.
The ball brgs are fine as long as you grease them properly. If you need to replace most or all the brgs then you could go to the rollers. Like Red says if you switch to discs you should change to thr rollers.
1956 Chevy 1/2-Ton Pickup
Top
#837351 - Wed Mar 21 2012 02:48 PM Re: Wheel Bearing Opinions [Re: NathanPlemons]
Loc: KY
Well I know that the bearings that are on it are not original, but they are the original style. I did a really really bone headed thing the other day and kinda screwed up the outer bearings. The bearings themselves and the races are still intact but I really should replace them. Was curious if I should go with the new style. Looks like there isn't much point, the old style has worked this long, why change it if it works right?
Top
#837372 - Wed Mar 21 2012 03:58 PM Re: Wheel Bearing Opinions [Re: NathanPlemons]
Flxible Offline
Boltergeist
the ball bearings work fine and are readily available at parts stores
Top
#837381 - Wed Mar 21 2012 04:44 PM Re: Wheel Bearing Opinions [Re: Flxible]
Wally / Montana Offline
Loc: The Last Best Place
A long time ago, someone in the bearing industry said on this forum that ball bearings, because of less contact area, can run cooler naturally that roller bearings and that they were perfectly fine in our trucks.
I suspect that the industry went to rollers because it's cheaper to make them. It's got to be easier and cheaper to make a uniform rod (and chop it up) than to make perfect metal balls one at a time. But that's just my guess.
25 Years of Daily Driving. Now with a '61 261, 848 head, Rochester Monojet carb, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
Top
#837399 - Wed Mar 21 2012 05:53 PM Re: Wheel Bearing Opinions [Re: Wally / Montana]
GMCpanel Offline
Loc: Springfield, MO
I don't know if they've switched, but at least until recently BMW was still using ball bearings.
1954 GMC De Luxe COE
Top
#837401 - Wed Mar 21 2012 05:55 PM Re: Wheel Bearing Opinions [Re: GMCpanel]
Mr. Lang Offline
Loc: Brentwood Bay, BC Canada
My model T has taper roller bearings.... Hahahaha. I think they're all good, with cleaning and grease.
Christopher
Pictures in Photodork
1949 GMC Panel Truck
1926 Model TT Truck
Top
#837467 - Wed Mar 21 2012 08:31 PM Re: Wheel Bearing Opinions [Re: Mr. Lang]
rustednuts Offline
Loc: Kingston, WA
In my opinion, I believe the tapered roller bearings are essentially a dumbed down version. They are very simple to adjust and even when not adjusted properly (within reason) they still seem to work without destroying the bearing and races.
My experience with ball bearings is that they have a specific torque value rather than 'spin the wheel and tighten' with typical tapered roller bearings. Ball bearings not adjusted properly seem a bit more capable of self destructing and fairly quickly at that.
Jeff
Hey guys, hows the weather? grin
Lifes to short to worry about how short life is.
1951 Oldsmobile Super 88 w/303 and hydramatic
My 1953 Chevrolet
1947.1 GMC Art Deco COE / 1947.1 Gallery
Top
#837504 - Wed Mar 21 2012 09:43 PM Re: Wheel Bearing Opinions [Re: rustednuts]
LONGBOX55 Online
Loc: DANVILLE IL
Something to consider, virtually ALL modern vehicles use ball bearings at least in the front, with FWD cars using the on all 4 wheels.
Bill Burmeister
Top
Page 1 of 3 1 2 3 >
Moderator:  cletis
