The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
15 registered (DaveV, brokenhead, cdandelivery, Cosmo, amsanto89, 49nut, 1 invisible), 242 Guests and 4 Spiders online.
Forum Stats
39,265 Registered Members
48 Forums
104,755 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
65 kid, mike in mo, ratmaster, ringgear
Image Posting Policy
New Reply
Topic Options
#836121 - Sat Mar 17 2012 04:42 PM Updating shocks
jjrockbush Offline
Loc: Florida
I have a 1948 3/4 ton. The suspension is 100% stock. Any advise on updating the old knee shocks to more modern shocks? I have seen shock mounts, but they are for the 1/2 ton.
Can some please tell me this is a cheap and easy fix?
_________________________
Who owns this car with the peace sign, mag wheels, and 4 on the floor?
Dude- 1948 Chevrolet Thriftmaser 3600
http://smg.photobucket.com/albums/v673/jjrockbush/1948%20Chevy%20Thriftmaster/
Top
#836593 - Mon Mar 19 2012 08:26 AM Re: Updating shocks [Re: jjrockbush]
elmer46 Offline
Loc: san antonio, tx
This is what I did. I have a 46 1/2 ton that I converted to tube shocks from knee action. I got some lower front tube type shock mounts off an Advance design series (47-50something.) that was in a junk yard. The mount was in a straight up and down orientation, I've seen some that have an angle towards the front of the truck I guess the choice is up to you. Anyway, got the lower shock mounts mounted to the leaf springs and measured the travel. Then I got on the monroe web site and found a shock with that travel with posts mounts on both ends ( choices are post or fork mount etc). These turned out to be off a 53 vette.
I made some upper mounts off of flat steel, bent them into a 90, welded some webbing for added strengh, attached to the frame and been running that way for about 5000 miles.
This is just a suggestion that worked for me I can't say it will work for you.
Top
#836657 - Mon Mar 19 2012 01:26 PM Re: Updating shocks [Re: elmer46]
Whitedog Offline
Loc: IL
The 47-55.1 AD trucks had basically the same front suspension. I wouldn't hesitate putting the 1/2 ton shock and mounts on a 3/4 ton. I looked in my LMC catalog and they had the same bracket and shock listed for the 1/2 and 3/4 ton for 50-55. Not to mention they used the same leaf spring setup from 47-55.1. Seems to me, it's a natural fit.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Top
#836712 - Mon Mar 19 2012 06:50 PM Re: Updating shocks [Re: Whitedog]
jjrockbush Offline
Loc: Florida
Thanks!.....(runs off to the LMC webpage....)
Top
#849329 - Sun May 06 2012 09:04 PM Re: Updating shocks [Re: jjrockbush]
jjrockbush Offline
Loc: Florida
After much research, I cannot figure a way to get tube shocks on the rear of the 3600 without much fabrication. The front is indeed the same as a 1/2 ton. The rear however, is much different. The leaf springs are mounted out board of the frame. In a 1/2 ton, the leaf springs are directly under the frame.
I am open to suggestions.
Top
#855038 - Tue May 29 2012 05:51 PM Re: Updating shocks [Re: jjrockbush]
hoozat Offline
Loc: Pennsylvania
chevy s-10 has the lower shock mounts, that will work on the back and what I did was bolted a piece of angle iron between the frame rails and made my own upper shock mounts u can see in my pictures
http://s629.photobucket.com/albums/uu14/kurtdh519/
all i did with the bottoms mounts was drill the u bolt holes closer so I could use my original springs
Top
Moderator:  SWEET
