The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
19 registered (dgrinnan, 2-Ton, 49nut, 1954Chevy5Window, DaveV, 55_2nd_Series, 2 invisible), 373 Guests and 4 Spiders online.
Forum Stats
39,264 Registered Members
48 Forums
104,745 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
58NAPCOGMC, boom construct, buddeal, Cal78, meanmim, RT1
Image Posting Policy
Page 1 of 3 1 2 3 >
New Reply
Topic Options
#835410 - Thu Mar 15 2012 12:23 AM New rubber on the 57
tri5trucking Offline
Loc: Creswell, Oregon
Had a short break in the weather and got out the fire truck with the newly powdercoated wheels and all new rubber. Much smoother than the old bias plys.
http://good-times.webshots.com/photo/2439991300101465522yVXRUK
Top
#835683 - Thu Mar 15 2012 10:37 PM Re: New rubber on the 57 [Re: tri5trucking]
Mike B Online
Loc: Hughesville, MD
Looking good! thumbs_up
I drove my fire engine looking just like that for about 3 years before I tore it down for a paint job.
Mike B smile
Edited by Mike B (Thu Mar 15 2012 10:37 PM)
Top
#835762 - Fri Mar 16 2012 09:22 AM Re: New rubber on the 57 [Re: Mike B]
Thanks Mike, I'm hoping to get it painted early summer.
Top
#835772 - Fri Mar 16 2012 10:11 AM Re: New rubber on the 57 [Re: tri5trucking]
3B Offline
Loc: B. C. Canada
Hy tri5trucking, that's a very nice looking truck! I've never seen a 57 with that style of ten bolt wheels, did you put some 58 hubs on it, or do you have adapters, or how did you put those wheels on that truck?
Top
#835791 - Fri Mar 16 2012 11:35 AM Re: New rubber on the 57 [Re: 3B]
lcfman Offline
Loc: Tenn
Nice truck is it a 322 buick engine?
Top
#835982 - Fri Mar 16 2012 11:41 PM Re: New rubber on the 57 [Re: lcfman]
The truck came factory with the big ten bolt pattern as far as I know. That made it very easy to swap over from the 20" split rims to the 22.5" tubeless. I chose to go with the painted wheel look as was traditional for the year but it's tempting to put the alcoa wheels all around. Like Mike B's truck it has the 322 buick motor.
Top
#836110 - Sat Mar 17 2012 03:46 PM Re: New rubber on the 57 [Re: tri5trucking]
Mike B Online
Speaking on the 322, what color is yours painted? Mine is Chevy Orange, but most sources list them as being Red. Can you add some engine pictures to your webshot page?
I don't have any literature on the big 10-lug axles being offered in 1957, but I do see a part number for the wheels in my 1963 parts book starting in 1957.
Fire trucks were always built different. My brother is the President of a small VFD and they just bought a single axle tanker with a 52K gvw, so anything is possible.
Mike B smile
Top
#836132 - Sat Mar 17 2012 05:38 PM Re: New rubber on the 57 [Re: Mike B]
Mine is also orange. It has a newer carb and alternator.
http://good-times.webshots.com/photo/2612692550101465522UEYTNQ
I would agree, government agencies always have different stuff. The 56 ton and a half Napco I had had a 261 which was available for 2 ton trucks but it was a power co. truck. I know a local fire department that bought stock piled new old stock diesel engines and was able to use them in new trucks without meeting that years emission standards.
Top
#836500 - Sun Mar 18 2012 09:31 PM Re: New rubber on the 57 [Re: tri5trucking]
Mike B Online
Tri5,
Thanks for the engine picture. My engine is the same color.
I noticed your water manifold under the T-stat housing isn't painted and maybe the timing cover. Can you check your engine block to see if it's painted. Everything on my engine is painted except for the Block and Timing Cover. I wonder if my block was replaced at some time? I can't find a serial number either...
Mike B smile
Top
#837113 - Tue Mar 20 2012 09:44 PM Re: New rubber on the 57 [Re: Mike B]
I can't tell if the block or timing cover was painted. They are pretty dirty. I can see the bell housing has orange paint on it and the driver side valve cover has the "loadmaster V8" still visible. I just had a couple pictures sent to me from a member of the Oregon fire museum. He thought I might be able to pick up some parts from these trucks. They aren't GM, but I had to send you the picture to check out the rear wheel covers. Both these trucks were built by Roney, same as mine. It would be great to get a booster reel and the wood ladders.
http://good-times.webshots.com/photo/2140559390101465522iYVUbO
Top
Page 1 of 3 1 2 3 >
