The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Indianapolis Fabrications
Talk to Randy Domeck
See what they
can do
for you
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
12 registered (Cablesmill, Britcon, bluesman, Hotrod Lincoln, Hollow65, 1 invisible), 471 Guests and 4 Spiders online.
Forum Stats
39,744 Registered Members
48 Forums
106,218 Topics
Most users ever online: 940 @ Tue Apr 04 2017 09:52 PM
Today's Birthdays
aree, atruckdoc, CGG_64C10, ET, Jimmy B, michaelnshannon, newton54, Righty, salvo, Sarah, Village_Idiot
Image Posting Policy
New Reply
Topic Options
#834210 - Sun Mar 11 2012 03:08 AM Budget hub cap adapter for rally wheels
Joe McNeel Offline
Loc: Elmo, UT, USA
I like the way the hub cap adapters on this page were made but making a casting is not something I do every day.
http://pic5.piczo.com/Millpower-Race-Engineering/?g=45768718
I finally came up with an inexpensive way to attach my hub caps. I started with some stock rally centers I found cheap on e-Bay. I removed the center part with a cut-off wheel and grinder. Then I drilled 3 evenly spaced holes 5/16" in from the outer edge and attached the clips with #10 machine screws, nuts and star washers. I salvaged the clips from some damaged wheels I had, but you can buy them from some of the venders for about $3 each.
http://web.etv.net/users/jmcneel/hc1.jpg
You could go with 4 or 6 clips as long as they are spaced evenly. Probably a good idea if you drive much on washboard gravel but 3 clips seem tight enough for my purposes. I then simply bolt the modified center to the rim with 5/16" cap screws.
http://web.etv.net/users/jmcneel/hc2.jpg
Then snap on the hub cap.
http://web.etv.net/users/jmcneel/hc3.jpg
Just the look I was going for.
http://web.etv.net/users/jmcneel/hc4.jpg
I've kept the chrome to a minimum for a more subtle look, only adding a few select pieces like my license plate frame!
http://web.etv.net/users/jmcneel/hc5.jpg
http://web.etv.net/users/jmcneel/59.html
_________________________
Joe McNeel
Joe\'s World
Top
#834411 - Sun Mar 11 2012 10:32 PM Re: Budget hub cap adapter for rally wheels [Re: Joe McNeel]
1Bad51 Offline
Loc: Las Vegas, Nevada
That turned out sweet, GREAT JOB ! I really like the way it looks
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
Top
#834839 - Tue Mar 13 2012 01:34 AM Re: Budget hub cap adapter for rally wheels [Re: 1Bad51]
bigbadswingdaddy Offline
Loc: san francisco
Now I know why I saved those ugly 4wd caps.
I had thought about modifying the 1/4 inch aluminum spacer plates that are sold with the 6 lug disc brake kits, or seperately to space the wheels out. This approach is definetely cheaper, as I already have a set of 4 4x4 center caps.
I nominate this to go in the tech tip section.
Top
#834887 - Tue Mar 13 2012 09:20 AM Re: Budget hub cap adapter for rally wheels [Re: bigbadswingdaddy]
Stuart_Giles Offline
Loc: Kent, United Kingdom
Good work there, and really great piece of recycling of the stock 6 lug rally wheel center caps too.
Edited by Stuart_Giles (Tue Mar 13 2012 09:21 AM)
Edit Reason: missing word
1950 Chevrolet 3100 (occasionally working) truck:https://c2.staticflickr.com/6/5490/30684982201_6dc479d18d_c.jpg
1928 Chevrolet AB National Phaeton: https://c4.staticflickr.com/6/5573/30137792083_42886d30a4_c.jpg
1932 Austin Special Sports: https://c8.staticflickr.com/6/5793/30116567183_1520e67c4d_z.jpg
Top
#834912 - Tue Mar 13 2012 11:40 AM Re: Budget hub cap adapter for rally wheels [Re: Stuart_Giles]
hankrags Offline
Loc: colorado springs, CO
My rallly wheels had the 4wheel drive caps, the fronts had the hole for the locking hubs. Someone made the centers out of a can lid. I used some of the round wide view mirrors from the parts store. They are chrome reflective and come in the right size, cheep too, a little rtv and you are done.
1954 Chevy Half-Ton
More pix on Shutterfly
More pix on Photobucket
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
Top
#835098 - Tue Mar 13 2012 10:25 PM Re: Budget hub cap adapter for rally wheels [Re: hankrags]
Joe McNeel Offline
Loc: Elmo, UT, USA
Thanks for the kind words. Stuart, I really would have rather been able to make a set like yours. They are almost to nice to cover up with hub caps.
Joe McNeel
Joe\'s World
Top
Moderator:  cletis
