The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
47 registered (48jim1ton, 1Plowboy, 3B, 1953 panel, 4 invisible), 373 Guests and 10 Spiders online.
Forum Stats
39,539 Registered Members
48 Forums
105,781 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
briang, emerson, finally have one, levi_69, paul stewart, Wild Turkey
Image Posting Policy
Page 3 of 3 < 1 2 3
New Reply
Topic Options
#830936 - Wed Feb 29 2012 10:25 AM Re: Leaking front main seal (I think) [Re: Denny Graham]
cmayna Offline
Loc: Menlo Park, Ca
Sounds like something I might consider adding to my tool chest as well.
_________________________
Craig's '50 Chevy 3100 5 window
My truck
If I'm not working on my truck, I'm fishing with the wife or smoking Salmon.
Top
#831258 - Thu Mar 01 2012 09:30 AM Re: Leaking front main seal (I think) [Re: cmayna]
DMGfifty Offline
Loc: Oregon Coast
I purchased a basic kit from napa. I think it was about $75 and included several bottles of dye (different for coolant, oil and even freon) a small black light and cleaner. I'll check when I get home and include a pic.
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Top
#831262 - Thu Mar 01 2012 09:49 AM Re: Leaking front main seal (I think) [Re: DMGfifty]
cmayna Offline
Loc: Menlo Park, Ca
Look at the bottom of the following Amazon link. Making a test kit looks pretty inexpensive. If you uncheck the coolant dye, a light and oil dye = $44.77 + postage.
http://www.amazon.com/Tracer-Products-TP34000601-Fluorescent-Detection/dp/B000JFHNTM
My truck
Top
#834766 - Mon Mar 12 2012 10:22 PM Re: Leaking front main seal (I think) [Re: cmayna]
joeflanagan Offline
Loc: Alexandria, VA
Cleaned the area up and ran the engine and watched to see where the oil is coming from. It's definitely coming from behind the plate that goes around the crank and cam gears (timing plate?). Anyway, it's the plate that mounts directly to the block behind the timing chain cover. If I had a groove worn on the harmonic balancer, would that be where oil would start showing up? Is a speedy sleeve my best option here?
1956 Chevy 3200
Top
#840513 - Sun Apr 01 2012 08:49 PM Re: Leaking front main seal (I think) [Re: joeflanagan]
joeflanagan Offline
Loc: Alexandria, VA
I finally got around to this today. I pulled the grill and the radiator and pulled the harmonic balancer. There is a decent groove in it and I installed a speedy sleeve, but I don't think that's where my leak is coming from.
I did a little research on the forum here and I think the culprit is the gasket that goes behind the front plate and specifically, the part that goes against the front main bearing cap. It seems to me if it were the balancer, oil would be coming out from the seal in the timing chain cover. But it's not. It's coming from behind the plate behind the timing chain cover. I suppose it could be the oil pan gasket, but that is new and I don't believe I boogered that up.
So tomorrow I'm dropping the oil pan, removing the main bearing cap, and taking a look.
1956 Chevy 3200
Top
#840678 - Mon Apr 02 2012 03:30 PM Re: Leaking front main seal (I think) [Re: joeflanagan]
ApacheFiend Offline
Loc: Dallas, TX
Joe-
I had the same issue with my 235. Since I needed to do some other things I pulled the engine and put it on a stand and took it apart. My front leak was being caused by the gasket behind the timing plate being broken. It was broken right where the plate makes contact with the front main bearing.
So there I found my answer....only after two pan gasket changes, speedi-sleave install and a broken thumb later I fixed the front leak. My memory wants to say that some one else had this issue not long ago and was able to fix it by dropping the pan and removing the front bearing cap to fix the gasket with some permatex or something.
58' 3200 235 3-speed/OD
1958 Chevrolet 3200
Top
#840689 - Mon Apr 02 2012 03:56 PM Re: Leaking front main seal (I think) [Re: ApacheFiend]
CASO Offline
Loc: Warrenton, Oregon
Could this one reason some have chosen to reverse and tap out those two bolts through the main cap so the timing cover can be removed without dropping the pan?
Give me ambiguity
or give me something else
Top
#840711 - Mon Apr 02 2012 05:24 PM Re: Leaking front main seal (I think) [Re: CASO]
joeflanagan Offline
Loc: Alexandria, VA
Remember when I said I didn't believe I boogered up the oil pan gasket on installation? Well now I believe. Because I did.
The front rubber end gasket was half off the rail. I probably knocked it off when I installed the pan. I had set it in some black RTV and the way it dried, you can tell that half the rubber gasket was never even in the cement. And some of the cement never got crushed. It hardened just the way I put it down.
Gonna fix everything up, put it all back together, and see what happens.
1956 Chevy 3200
Top
#840853 - Tue Apr 03 2012 08:53 AM Re: Leaking front main seal (I think) [Re: joeflanagan]
don stocker Offline
Loc: osceola, wi
The RTV doesn't work well to hold things in place, its more to fill a small void. Get an adhesive to hold things in place. Do a search and you'll see that many opinions are available as to which works best. Best advise is to have things clean and oil free before you apply any product to hold a gasket in place.
Top
Page 3 of 3 < 1 2 3
Moderator:  53moneypit, Woogeroo
