The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
50 registered (48jim1ton, 1Plowboy, 3B, 1953 panel, 4 invisible), 372 Guests and 10 Spiders online.
Forum Stats
39,539 Registered Members
48 Forums
105,781 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
briang, emerson, finally have one, levi_69, paul stewart, Wild Turkey
Image Posting Policy
Page 8 of 9 < 1 2 3 4 5 6 7 8 9 >
New Reply
Topic Options
#822999 - Sat Feb 04 2012 06:33 PM Re: Taint no such thing as new 3.90 or 4.10 gears!!! [Re: 1951Chevy1Ton]
Denny Graham Offline
Loc: Sandwich, IL
Sure you can send me some pics but as I've said, I'm not an expert, just tellin' what I've seen and what my research has turned up.
DG
Top
#833838 - Fri Mar 09 2012 09:23 PM Re: Taint no such thing as new 3.90 or 4.10 gears!!! [Re: Denny Graham]
GMCpanel Offline
Loc: Springfield, MO
It doesn't look like it's been mentioned in here, but the gear sets are also marked on the edge of the ring gear. That's how I found my 4.11 pumpkin in a pick-n-pull junkyard years ago. The dome cover on the other side of the banjo axle comes off easily, and it's then simple to use one tire to spin the axle until you can find the markings - as long as the driveshaft is disconnected or the transmission is in neutral.
From what I've read, the 3.90 gearsets were only used in one fancy trim level truck for one year, and are consequently incredibly rare. The 4.11s, while not common, are far more likely to be located than the 3.90s. If you want to get really ridiculously rare, try finding a Detroit Locker unit. They went out of production as soon as the Eaton axle design was dropped in the early 70s.
_________________________
1954 GMC De Luxe COE
Top
#833853 - Fri Mar 09 2012 10:05 PM Re: Taint no such thing as new 3.90 or 4.10 gears!!! [Re: GMCpanel]
LONGBOX55 Offline
Loc: DANVILLE IL
The Detroit Locker was offered in the Spicer/Dana 60 and 70 in GM trucks well into the '70s. The "3.90" 3/4 ton axle doesn't exist as an oem option in GM products, only as an aftermarket gearset that's no longer made.
Bill Burmeister
Top
#833902 - Sat Mar 10 2012 12:21 AM Re: Taint no such thing as new 3.90 or 4.10 gears!!! [Re: LONGBOX55]
GMCpanel Offline
Detroit Locker units have been made for all sorts of axles, but the specific version for the Eaton banjo axles is difficult to find.
From the best information that I've found, there was a factory 3.90 gearset for the HO52/72 axle, but it's rare as hens' teeth. Supposedly, it was only available on 1970-ish big block automatic 3/4-tons. Long ago I spoke to someone who found one "in the wild," but that's the only one I've heard of. I'm sure that 1969/70/71 BBC 3/4-ton autos aren't exactly common.
Edited by GMCpanel (Sat Mar 10 2012 12:22 AM)
Top
#833919 - Sat Mar 10 2012 01:57 AM Re: Taint no such thing as new 3.90 or 4.10 gears!!! [Re: GMCpanel]
BC59 Offline
Loc: N.E. Oregon
Chev also use some spicer / dana axle behind the 396 / 402 in 1969/70/71
BC
Top
#838150 - Sat Mar 24 2012 12:23 AM Re: Taint no such thing as new 3.90 or 4.10 gears!!! [Re: BC59]
Highflyer Offline
Loc: Calgary, Alberta
Just picked up my 4.10 gearset fron Ryan Pope. A nicer gentleman you will never meet.
Thank you very much, Ryan. Well worth the drive. :-)
Quite a nice yard (for a stovebolter, lol) with lots of projects. He likes diesels. Nice installs.
\'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 1986 Jaguar XJ-S, 89 Cavalier Z24, 96 Pontiac Sunfire GT, 2010 Jeep Patriot. No, they don't all run.
My other ride is a (B737)no, (B767)no, A320.
Top
#838233 - Sat Mar 24 2012 10:58 AM Re: Taint no such thing as new 3.90 or 4.10 gears!!! [Re: Highflyer]
Tango Offline
Loc: Texas
Hey Highflyer --- is that 4.11 set for your '49? And was it off-the-shelf or custom cut? Did a quick search but didn't see any other references.
1946 1.5-Ton Chevy Shorty Bus
More pix on Flickr
All my best --- Tango
Top
#838358 - Sat Mar 24 2012 08:20 PM Re: Taint no such thing as new 3.90 or 4.10 gears!!! [Re: BC59]
LONGBOX55 Offline
Loc: DANVILLE IL
Yes. They had a 3.54 gearset in them. The Heritage site also lists it being available in '68 in 3/4 tons with the 396.
Bill Burmeister
Top
#838365 - Sat Mar 24 2012 08:33 PM Re: Taint no such thing as new 3.90 or 4.10 gears!!! [Re: GMCpanel]
LONGBOX55 Offline
Loc: DANVILLE IL
Originally Posted By GMCpanel
[quote=LONGBOX55]The Detroit Locker was offered in the Spicer/Dana 60 and 70 in GM trucks well into the '70s. The "3.90" 3/4 ton axle doesn't exist as an oem option in GM products, only as an aftermarket gearset that's no longer made.
From the best information that I've found, there was a factory 3.90 gearset for the HO52/72 axle, but it's rare as hens' teeth. Supposedly, it was only available on 1970-ish big block automatic 3/4-tons. Long ago I spoke to someone who found one "in the wild," but that's the only one I've heard of. I'm sure that 1969/70/71 BBC 3/4-ton autos aren't exactly common. [/quote] Actually, the big block 3/4 tons are quite common. Especially in Camper Special form. Almost every single one I've seen had a Spicer rearend, oor the 4.10 geared Eaton. The only listing I've found for a factory built Eaton with 3.90 gears was for the '55 1rst and early '55 2nd Napco conversion for 1/2 tons, which used the 3/4 ton axle for the front. Otherwise, GM shows no listing for that ratio in 3/4 or 1 ton.
Bill Burmeister
Top
#838388 - Sat Mar 24 2012 10:21 PM Re: Taint no such thing as new 3.90 or 4.10 gears!!! [Re: LONGBOX55]
Highflyer Offline
No, it's a normal center section from a 67-72 3/4 or 1 ton big block automatic.
Top
Moderator:  SWEET
