The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Spring is here!
If you are bringing the old truck out of winter storage, or up from the woods, be sure to check the Tech Tip for a few helpful hints.
If you have some work to do before you go cruising, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
8 registered (78buckshot, dunfire, 5 Window 9434, coilover, Jimmie D, Justhorsenround), 450 Guests and 4 Spiders online.
Forum Stats
39,646 Registered Members
48 Forums
105,730 Topics
Most users ever online: 940 @ Tue Apr 04 2017 09:52 PM
Today's Birthdays
big 51, chevypanel52, ray1958, RickA
Image Posting Policy
Page 1 of 7 1 2 3 4 5 6 7 >
New Reply
Topic Options
#833419 - Thu Mar 08 2012 01:26 PM Climbing Hills?
Lucille Offline
Loc: Murphy, NC
I don't like the performance I'm getting climbing hills. When I approach a hill I have to really give Lucille gas to build up speed, however, once I am maybe half way up the hill she starts cutting out on me. I let my foot off the gas slightly and she reacts and catchs up with power a bit, then I give her a little more gas and she'll start cutting out a bit more. It's this back and forth thing we go through. I've got her set to the correct RPM (475 approx), new points, condenser, distributor cap and plugs. Should I be playing with the throttle as I climb a hill? Can someone explain to me the usage of the throttle? Or do I have another obvious problem that I don't understand? This old technology stumps me sometimes. Especially on the performance side of things.
_________________________
"Lucille" ..... Proud Member of the "Southern Stovebolts"
David Wolff
1946 Chevy 1/2-ton
http://s1145.photobucket.com/albums/o510/Wolffman26/
Top
#833420 - Thu Mar 08 2012 01:31 PM Re: Climbing Hills? [Re: Lucille]
truckernix Offline
Loc: Bracebridge Ontario Canada
The throttle is used to bring up the idle when it is warming up. I also use mine to set the idle a little higher as a convenience starting on hills. If you engine is running correctly there shoudl be no need to back off the gas pedal on a hill.
1951 1 Ton Completed
Top
#833425 - Thu Mar 08 2012 01:47 PM Re: Climbing Hills? [Re: truckernix]
Old 'Burb Lover Offline
Loc: Calgary Alberta
Something similar happened to me once. Turned out to be a vacuum leak. After I found the problem and fixed it everything was fine.
I don't know if that's your case, but its something to check into.
"People sleep easy in their beds because rough men stand ready to do violence on their behalf."
"That rifle on the wall of the labourer's cottage, or working class flat, is the symbol of democracy. It is our job to see that it stays there."
- George Orwell
"Those who beat their swords into plowshares end up plowing for those who kept their swords."
- Benjamin Franklin
Top
#833429 - Thu Mar 08 2012 02:08 PM Re: Climbing Hills? [Re: Old 'Burb Lover]
hankrags Offline
Loc: colorado springs, CO
I would check the fuel filter and fuel pump.
1954 Chevy Half-Ton
More pix on Shutterfly
More pix on Photobucket
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
Top
#833493 - Thu Mar 08 2012 06:19 PM Re: Climbing Hills? [Re: hankrags]
Denny Graham Offline
Loc: Sandwich, IL
Nope, I can lug my 216 with the Carter W-1 down in fourth gear
to 20 mph on a hill and floor it and it's a steady pull right up
to cruising speed.
DG
Top
#833519 - Thu Mar 08 2012 07:37 PM Re: Climbing Hills? [Re: Lucille]
Hotrod Lincoln Offline
Loc: Dellrose, TN
You mentioned changing everything but plug wires. They're definitely a possibility when dealing with a miss under load. If it's a sharp loss of power, not a gradual loss and a surge back to normal pulling, it's probably ignition, not fuel. Try a new set of plug wires before you chase any more gremlins.
Who says I live in a rough neighborhood- - - - -?
Just because I'm a tail gunner on a beer truck, maybe?
"He ain't even got a noddin' acquaintance with the truth- - -let alone a speakin' one!"
Top
#833665 - Fri Mar 09 2012 08:59 AM Re: Climbing Hills? [Re: Hotrod Lincoln]
Joe H Offline
Loc: Lee's Summit Mo. 64086
Mine did that when it was running lean, check float level, fuel supply, and for a vacuum leak. I bet your milage is decent having to let off all the time !
Joe
1937 Chevrolet Inline-powered Streetrod
Top
#833758 - Fri Mar 09 2012 03:07 PM Re: Climbing Hills? [Re: Hotrod Lincoln]
Lucille Offline
Loc: Murphy, NC
Jerry, I just installed new ignition wires this morning. I think I may be firing on all cylinders but its hard to tell. Sounds and feels like it. At idle I get these little fart sounds out of the tail pipe like something is a little off. Anyway I took her out and tryed to do Denny's trick of climbing a hill at 20MPH and then accelerating to gain speed. No such luck she still is lacking the power to climb. I got her on level ground and ran her a couple of miles. At one point when I was turning around to come back she back-fired through the carb one time in second gear going really slow. So I thought that it must be the timing. I had her advanced quite a bit, so I retarded her to 4 degrees. Tested her again and kept playing around with the distributor thinking I'll eventually find the sweet spot. It seemed to work the best at about 2 degrees advanced. Still the power is lacking. I'm thinking of removing the vacuum line to see if its gunked up. It's really got me scratching my head. I mean these are basic machines. It shouldn't be that difficult to figure out but I'm really stumped. Any further tests or suggests about where to go next? Was there ever a standard setting to retard the distributor a couple degrees as they came out of the factory? Just curious.
Oh, one other thing. This afternoon when I was out making distributor adjustments, when I would gun her I'd get a whole bunch of back-fire farts out of the exhaust no matter where I set the distibutor. What does that mean?
David Wolff
1946 Chevy 1/2-ton
Top
#833792 - Fri Mar 09 2012 06:16 PM Re: Climbing Hills? [Re: Lucille]
don stocker Offline
Loc: osceola, wi
Maybe put a vacuum gauge on it and see what it says? Have you adjusted the valves lately? You could always do a compression test and see what it says? The a couple of ideas ......
Top
#833801 - Fri Mar 09 2012 06:52 PM Re: Climbing Hills? [Re: Lucille]
Loc: Dellrose, TN
If you've got a manual choke, try pulling the knob out a little to create a slightly rich mixture. It's possible the power valve in the carburetor isn't opening up and the drop in manifold vacuum as you go to open throttle is causing a lean-out. Have you checked the fuel volume to see if the pump is delivering enough gas? Disconnect the fuel line at the carb, run the line into a 1-quart catch can, and crank the engine up. It should flow at least a pint in 30 seconds at idle speed, running on the fuel in the float bowl.
Also, try a cylinder balance test, where you run the engine at a constant 1,000-1,200 RPM with a tachometer and a vacuum gauge connected. Disconnect one spark plug wire at a time and record the RPM and vacuum drop for each one. If you've got one with a leaky valve, etc. the RPM and vacuum will not drop as much as a healthy cylinder.
Top
Moderator:  53moneypit, Woogeroo
