The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
30 registered (53 green 1- ton, BC52, Chilidogg, Bills Auto Works, Cosmo, DinoKruzOrdinanc, 2 invisible), 443 Guests and 4 Spiders online.
Forum Stats
39,277 Registered Members
48 Forums
104,811 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
Jimmymack68, kc0kfg, Nic-Rebel450CA, tommy65gmc
Image Posting Policy
New Reply
Topic Options
#832626 - Mon Mar 05 2012 09:38 PM 250 smoking around the manifolds
bamaboy2223 Offline
Loc: Alabama
My trucks smoking a little under the hood around the exhaust manifold, well i think anyway cuz on the 250 the intake and exhaust are on the same side, but its smoking a little under the hood and from the best i could tell thats where its coming from. Also it puts some smoke out the tail pipe. Where should i start here?
_________________________
1966 GMC
Top
#832658 - Mon Mar 05 2012 10:35 PM Re: 250 smoking around the manifolds [Re: bamaboy2223]
Wrenchbender Ret. Online
Loc: Lenexa Ks.
Probably the valve cover gasket is leaking & the oil is running down to the manifolds.
1956 Chevy 1/2-Ton Pickup
Top
#833228 - Wed Mar 07 2012 08:38 PM Re: 250 smoking around the manifolds [Re: Wrenchbender Ret.]
bamaboy2223 Offline
Loc: Alabama
i just replaced the valve cover with new gasket and siliconed it
1966 GMC
Top
#833270 - Wed Mar 07 2012 10:30 PM Re: 250 smoking around the manifolds [Re: bamaboy2223]
Loc: Lenexa Ks.
It may be blow by. Does smoke come out the breather cap when it is running?
Top
#833365 - Thu Mar 08 2012 09:17 AM Re: 250 smoking around the manifolds [Re: Wrenchbender Ret.]
bamaboy2223 Offline
Loc: Alabama
No it doesn't have any blow by. When I replaced the valve cover with a chrome one i have to bend it to fit right and it bent the a lip out in the backside and it was leaking out well I removed it and straightened it out and put a new cork gasket on and ran the truck and it's still smoking
1966 GMC
Top
#833423 - Thu Mar 08 2012 01:38 PM Re: 250 smoking around the manifolds [Re: bamaboy2223]
starfire4 Offline
Loc: White Cloud, MI, USA
Is this sudden, like since you replaced the valve cover & gasket?
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
Top
#833530 - Thu Mar 08 2012 08:16 PM Re: 250 smoking around the manifolds [Re: starfire4]
bamaboy2223 Offline
Loc: Alabama
yeah it is. It smoked before and i knew it was cuz the bent lip on the valve cover so i fixed that and its still smoking now
1966 GMC
Top
#833655 - Fri Mar 09 2012 08:21 AM Re: 250 smoking around the manifolds [Re: bamaboy2223]
johntsmith Offline
Loc: Tampa Bay FL
Sounds like you have an exhaust leak at the manafold. If so it should be making some hissing noise. Also sounds like you either have a valve seal problem or rings. You claim no blow-by but are you sure? Take the breather out of the valve cover and give it a few revs. If you get a lot of smoke coming out the valve cover it's time to replace the seals. Did you do a compression test on the engine?
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Top
Moderator:  Hambone, sixtyfive c-10
