The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
3 registered (jacksont, Super55, 1 invisible), 433 Guests and 5 Spiders online.
Forum Stats
39,267 Registered Members
48 Forums
104,774 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
1 Dollar, aerotruk63, GTA Scott, mb53, Norman Meloche, pauldumont, rscott, steven simpson, thor
Image Posting Policy
Page 1 of 2 1 2 >
New Reply
Topic Options
#831648 - Fri Mar 02 2012 05:04 PM Heater. Do I have one?
Spooky Offline
Loc: California
I have a new 65 C20 and I have been doing things to make it better. I installed a new fuse box and finally got the fan working. It then occurred to me that there is no heater control! There is an air/fan knob and the up down control toggle on the heater. The hoses in and out of the heater box on the firewall are both hot when running. I had a C10 in high school. I distinctly remember there being heat and a way to control it... sorta.
here are a couple of shots of my controls.
[url=<a href="http://s49.photobucket.com/albums/f262/magicalmisfits/?action=view&current=photo2.jpg" target="_blank"><img src="http://i49.photobucket.com/albums/f262/magicalmisfits/photo2.jpg" border="0" alt="Photobucket"></a>]Fan/Air Toggle[/url]
[url=<a href="http://s49.photobucket.com/albums/f262/magicalmisfits/?action=view&current=photo3.jpg" target="_blank"><img src="http://i49.photobucket.com/albums/f262/magicalmisfits/photo3.jpg" border="0" alt="Photobucket"></a>]Up Down Vent control[/url]
Top
#831673 - Fri Mar 02 2012 06:18 PM Re: Heater. Do I have one? [Re: Spooky]
Dado Offline
Loc: ga
Pull the fan knob out To heat truck
Top
#831715 - Fri Mar 02 2012 08:32 PM Re: Heater. Do I have one? [Re: Dado]
4-5-6 Chevy Trucks Offline
Loc: Kansas City, KS
There are two heater/defroster systems available on your '65 Chevy C20...Thrift-Air (single pull knob/2-speed) or Deluxe-Air (three levers/3-speed). On the Thrift-Air system, the defrost is activated by flipping the lever on the under-dash distribution box. The heat/defrost is controlled, via the 3-lever dash control on the Thrift-Air system.
_________________________
Tony Smith
4-5-6 Chevy Trucks
501 Scott Avenue
Kansas City, KS 66105
913-207-7789
4-5-6chevytrucks@sbcglobal.net
Photos: http://www.flickr.com/photos/4-5-6chevytrucks/sets/
Custom Parts: http://www.flickr.com/photos/4-5-6chevytrucks/sets/72157627022818563/
www.4-5-6chevytrucks.com
Top
#831727 - Fri Mar 02 2012 09:30 PM Re: Heater. Do I have one? [Re: 4-5-6 Chevy Trucks]
Spooky Offline
Loc: California
Hmmmm Guess I need to figure out why I don't get heat when I pull the knob. Maybe whatever is supposed to get pulled is disconnected.The old owner was clipping wires for no apparent reason and I am reattaching them as I find them!
Top
#831776 - Fri Mar 02 2012 11:56 PM Re: Heater. Do I have one? [Re: Spooky]
JohnDeere80 Offline
Loc: MN
My 65 has a lever on the on the Rt side of the heater box under the hood. My truck has the cable runing through the firewall and then cut off. The lever controls how much heat is let inside the cab
http://www.youtube.com/sow2323
Top
#831777 - Sat Mar 03 2012 12:19 AM Re: Heater. Do I have one? [Re: JohnDeere80]
The 60/66 Factory Assembly manual would be a big help for you on your project for things like this.
Tony Smith
4-5-6 Chevy Trucks
501 Scott Avenue
913-207-7789
Top
#831986 - Sat Mar 03 2012 08:59 PM Re: Heater. Do I have one? [Re: 4-5-6 Chevy Trucks]
Spooky Offline
Loc: California
OK I have traced the push pull cable and all is in order. Tommorow me and my Son-in-law are going to try flushing the system to see if we have a clog.
Top
#831990 - Sat Mar 03 2012 09:05 PM Re: Heater. Do I have one? [Re: Spooky]
A clog in the coolant system, will not keep the air from flowing. Pull the power wire off the blower motor, below the under-hood heater box. With a jumper wire, run power directly to the blade connector on the blower motor from the positive on the battery. They motor should spin-up, at full speed, since you are giving it a full 12v. If the blower motor does not spin, this is your issue. If the blower motor does power up, it is in your dash controls.
Tony Smith
4-5-6 Chevy Trucks
501 Scott Avenue
913-207-7789
Top
#832060 - Sun Mar 04 2012 02:16 AM Re: Heater. Do I have one? [Re: 4-5-6 Chevy Trucks]
Spooky Offline
Loc: California
I looked back and I guess I didn't present this clearly. The fan works fine I just can't get warm air. I thought the push pull cable was the culprit but it works fine. So now to trouble shoot the wet part of the heater.
Top
#832246 - Sun Mar 04 2012 08:14 PM Re: Heater. Do I have one? [Re: Spooky]
In the distribution box, under the dash, there is a heater resistor, that glows, red-hot, when it is functioning properly, on High setting. Check this also.
Tony Smith
4-5-6 Chevy Trucks
501 Scott Avenue
913-207-7789
Top
Page 1 of 2 1 2 >
Moderator:  Hambone, sixtyfive c-10
