The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
36 registered (1953 panel, 40_chevy, 2ton46, '54 3600, 2-Ton, 3B, 2 invisible), 570 Guests and 4 Spiders online.
Forum Stats
39,407 Registered Members
48 Forums
105,407 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
19chevy38, BF Finster, BigBambino22, crcmk7w, dmtexas, jay smith, Jim Williams 7w, Kevin W. Johnson, Noe_swede, pablos49
Image Posting Policy
New Reply
Topic Options
#831377 - Thu Mar 01 2012 05:40 PM trans wont gear down
wodniw5 Offline
Loc: north carolina
1977 chevy stepside. I swapped out the 305 and original 400th trans and put in a 350 350th trans. ( BE CLEAR I HAVE NEVER DONE THIS MUCH BY MYSELF BEFORE) engine runs great trans shifts smooth but wont gear down. I put on an edlebrock performer intake and a holley 900 4 bbl carb. I had to add a bracket for the throttle cable and trans cable that came with the carb kit. do i need to adjust the trans cable or am i missing something?? any and all suggestuons welcome. Paul
_________________________
http://1951chevrolet.shutterfly.com/
Top
#831395 - Thu Mar 01 2012 06:50 PM Re: trans wont gear down [Re: wodniw5]
48bigtrucks Online
Loc: Center Point, Iowa
The cable should be pulled all the way out when the throttle is wide open. That's the adjustment for the kick down cable. Also be sure you have a vacuum source for the modulator,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Top
#831488 - Thu Mar 01 2012 11:36 PM Re: trans wont gear down [Re: wodniw5]
Hotrod Lincoln Online
Loc: Dellrose, TN
The only function of the cable on a 350 is for kickdown. Just as the throttle reaches wide open, the cable should reach its full travel. Shift points on a 350 are controlled by the modulator and the governor pressure, which is generated by the speed of the driveshaft. Adjust the kickdown cable to be full forward at wide open throttle and it should function. If it doesn't, there is an internal problem with the kickdown band and/or the servo that applies it. That's overhaul territory!
What would a bulldog cross-bred with a Shi Tzu be called?
"He ain't even got a noddin' acquaintance with the truth- - -let alone a speakin' one!"
Top
Moderator:  KCMongo
