The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Indianapolis Fabrications
Talk to Randy Domeck
See what they
can do
for you
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
12 registered (Cablesmill, Britcon, bluesman, Hotrod Lincoln, Hollow65, 1 invisible), 471 Guests and 4 Spiders online.
Forum Stats
39,744 Registered Members
48 Forums
106,218 Topics
Most users ever online: 940 @ Tue Apr 04 2017 09:52 PM
Today's Birthdays
aree, atruckdoc, CGG_64C10, ET, Jimmy B, michaelnshannon, newton54, Righty, salvo, Sarah, Village_Idiot
Image Posting Policy
Page 1 of 2 1 2 >
New Reply
Topic Options
#827583 - Sat Feb 18 2012 07:59 PM Signal stat turn signal unit wiring (eigth wire???
DadsApache Offline
Loc: Owego, NY
My 57 Chevy truck has a bolt-on signal-stat turn signal unit. It has 8 (not seven) wires coming from the unit. I've identified the regular seven wires, but does anyone know what the eight wire may be used for? It is grey or light brown in color.
This unit has a green light on the end of the turn lever.
_________________________
Two 1957 Chevy Step Sides
1988 Fiero Formula
1987 Fiero GT
1984 Fiero Indy
... yes I like Fieros also..
Top
#827590 - Sat Feb 18 2012 08:18 PM Re: Signal stat turn signal unit wiring (eigth wire??? [Re: DadsApache]
Frank50 Offline
Loc: Central IL, again
I had the same kind of signal unit on my 50 Chevy. Somewhere I found a wiring diagram online, but I don't remember where. This unit wires into the parking lights and brake lights I remember that. Mine was old and the contacts were corroded - but eventually I got all functions to work properly including the 4-way flashers. Does your have that feature? I will look for the wiring schematic.
Look at this here and the image or 2 previous and next.
Edited by Frank50 (Sat Feb 18 2012 08:28 PM)
Frank50
Top
#827593 - Sat Feb 18 2012 08:25 PM Re: Signal stat turn signal unit wiring (eigth wire??? [Re: Frank50]
Roadmarks Offline
Loc: Raleigh NC USA
On the H.A.M.B., there is an 8 wire diagram. See if this helps!
http://www.jalopyjournal.com/forum/showthread.php?t=200703
Les
1956 Chevy Panel
1969 Chevy C20 Panel Truck
1971 Chevy C-10
More pix on Photobucket
"The Urban Home for Wayward Trucks"
Top
#827615 - Sat Feb 18 2012 09:17 PM Re: Signal stat turn signal unit wiring (eigth wire??? [Re: Roadmarks]
cletis Offline
Loc: Parker County Texas
According to this diagram the eighth wire is for the park lights. The way I read this you don't need to replace the front sockets with dual filament. It will light the single filament bulbs when the headlight switch is in park position or flash the appropriate light when in 'turn'.
Pretty nifty switch, I'd say.
My TRUCKS website
Top
#827646 - Sat Feb 18 2012 10:35 PM Re: Signal stat turn signal unit wiring (eigth wire??? [Re: cletis]
crenwelge Offline
Loc: Fredericksburg, Texas
Charlie, you are reading the diagram right. It is a nifty switch and its still being made. I have several on hand for spares, but now the drivers are too lazy to lift their leg so they want the ones with the dimmer switch built in too.
Top
#827733 - Sun Feb 19 2012 08:29 AM Re: Signal stat turn signal unit wiring (eigth wire??? [Re: Frank50]
DadsApache Offline
Loc: Owego, NY
Thank you for the info which was very helpful. I assume from the diagram that I can simply tape off the 8th wire (red with green tracer) if I decide not to use the 4-way flasher feature, right?
1988 Fiero Formula
1987 Fiero GT
1984 Fiero Indy
Top
#827734 - Sun Feb 19 2012 08:29 AM Re: Signal stat turn signal unit wiring (eigth wire??? [Re: crenwelge]
Frank50 Offline
cletis, that's exactly how mine worked. I replaced the parking light bulbs with higher watt (brighter) bulbs.
DadsApache, the red w green tracer goes from the parking light terminal on the light switch to the 800 unit. I think if you left that off you wouldn't have parking lights...
Edited by Frank50 (Sun Feb 19 2012 08:33 AM)
Edit Reason: comment
Frank50
Top
#827736 - Sun Feb 19 2012 08:31 AM Re: Signal stat turn signal unit wiring (eigth wire??? [Re: cletis]
DadsApache Offline
Loc: Owego, NY
1988 Fiero Formula
1987 Fiero GT
1984 Fiero Indy
Top
#827948 - Sun Feb 19 2012 06:27 PM Re: Signal stat turn signal unit wiring (eigth wire??? [Re: DadsApache]
cletis Offline
The 8th wire has nothing to do with the 4 way flashers. As has been stated, it connects to the park light terminal of the headlight switch.
You can dead end the 8th wire if you want to. However, if you don't change your front sockets to to use dual filament bulbs you won't have front park lights because you have cut the power to them when you wired the turn signals to them.
Why not just hook the red/green wire to the park light terminal of the light switch and dead end the original park light wire? It will take less time than changing to dual filament sockets.
By the way, if you do it your way you will need to dead end the wires you cut from the park light sockets to prevent them from shorting out when you turn on the headlights because the switch will make momentary contact with the park light circuit when you turn on the headlights.
My TRUCKS website
Top
#828275 - Mon Feb 20 2012 07:34 PM Re: Signal stat turn signal unit wiring (eigth wire??? [Re: cletis]
Frank50 Offline
If you wire the 800 unit as shown in the schematic you don't have to change to dual filament sockets. smile
Edited by Frank50 (Mon Feb 20 2012 07:35 PM)
Frank50
Top
Page 1 of 2 1 2 >
Moderator:  Rusty Rod
