The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Grilles for 1934, 35, and 36 GM trucks
To 1934-35 and 1936 GM Truck Customers
A limited number of new grilles have just arrived! They are totally SHOW QUALITY, mirrow-polished, stainless steel. Includes outer reinforcing band, vertical center bars, and special customer fasteners to attach to your outer shell.
LOOK HERE
and see
Limited Quantity!
Old Chevy Trucks.com
Stovebolt Site Search
Old Truck Calendars
2015 Calendars!
12 months of GMC Stovebolts
There are over 10 to choose from.
Check for details!
Who's Online
28 registered (53 green 1- ton, 5 Window 9434, 69L46Vert, 2-Ton, Classicdreamer, brokenhead), 95 Guests and 4 Spiders online.
Forum Stats
37,087 Registered Members
46 Forums
97,813 Topics
Most users ever online: 399 @ Wed Apr 09 2014 10:26 PM
Today's Birthdays
Joe Way
Image Posting Policy
Page 1 of 2 1 2 >
Topic Options
#824365 - Wed Feb 08 2012 11:04 PM Rusty cab inside
green_truck Offline
Loc: Roy, Oregon
Can anybody help with rust removal on the inside of the cab on my 47 loadmaster
Top
#824404 - Thu Feb 09 2012 03:30 AM Re: Rusty cab inside [Re: green_truck]
healingbear Offline
Loc: Northern California
green_truck, do you have some pics so that we may see the extent of your rust problem ?
I used wire wheels attached to a drill to get most of the rust... I did not have the $$$ or access to a sand blaster... Hard to get place like under the dash I used wire brush and steel wool...
Here is what mine looked like,
Interior Restore 2009
Interior 2010
Dash
_________________________
In my family for over 50 Years
54 Chevy 3104 3 Window Hydra-Matic Photobucket Pics
54 Chevy 3104 3 Window Hydra-Matic Comcast Pics
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
Top
#824485 - Thu Feb 09 2012 10:31 AM Re: Rusty cab inside [Re: healingbear]
truckernix Offline
Loc: Bracebridge Ontario Canada
For under the dash I found one of the those flexible drives for the drill pretty handy.
1951 1 Ton Completed
Top
#824492 - Thu Feb 09 2012 10:52 AM Re: Rusty cab inside [Re: truckernix]
DrewP Offline
Loc: Glassboro,NJ
When using a wire or disc abrasive it's best not to use a high speed grinder for this process. They can generate enough heat to warp the metal if held in one spot too long. A slower orbital sander would be better to use.
Drew
Top
#824692 - Thu Feb 09 2012 11:47 PM Re: Rusty cab inside [Re: DrewP]
green_truck Offline
Loc: Roy, Oregon
Anything quicker than a wire wheel
Top
#824694 - Thu Feb 09 2012 11:49 PM Re: Rusty cab inside [Re: green_truck]
green_truck Offline
Loc: Roy, Oregon
I don't have any pics yet the rust is not very bad but I want to clean it good before I paint
Top
#824697 - Fri Feb 10 2012 12:01 AM Re: Rusty cab inside [Re: green_truck]
Don G. Offline
Loc: Central Valley Calif.
Look for a shop that specializes in dipping your body into a tank of solution that removes all the Rust,Paint and grime. The cab must be completly striped of all the inside and outside parts switches, gauges,door handles, window frames etc..
The cab will come out really clean to bare metal and will have all the Rust Body filler or visiual holes from where the rust used to be if there is any. Then you can coat it with a rust preventive material until you get to the body work if need be.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
Top
#824882 - Fri Feb 10 2012 03:48 PM Re: Rusty cab inside [Re: Don G.]
Super55 Offline
Loc: Maple Ridge, BC
Don G.
When you say rust preventative material, are you talking about shooting some primer on it, or some other coating? Would it be something like Rust Mort? I have only had experience with small parts and clean and paint generally the same day.
1948 Chevy 2-Ton
Top
#824946 - Fri Feb 10 2012 06:54 PM Re: Rusty cab inside [Re: Super55]
DrewP Offline
Loc: Glassboro,NJ
green truck, Just so happens that the current issue of Vintage Truck magazine has an informative article on rust removal you may like to read. The mag is available at Barnes and Noble among other book stores.
Drew
Top
#824983 - Fri Feb 10 2012 09:09 PM Re: Rusty cab inside [Re: DrewP]
green_truck Offline
Loc: Roy, Oregon
Thanks for the info I will check it out.
Top
Page 1 of 2 1 2 >
Moderator:  Fourbrads
