The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Spring is here!
If you are bringing the old truck out of winter storage, or up from the woods, be sure to check the Tech Tip for a few helpful hints.
If you have some work to do before you go cruising, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
44 registered (63stepsideLB, 1953 panel, 6571, 54CarryAll, 49nut, 2 invisible), 452 Guests and 6 Spiders online.
Forum Stats
39,624 Registered Members
48 Forums
105,623 Topics
Most users ever online: 940 @ Tue Apr 04 2017 09:52 PM
Today's Birthdays
53 green 1- ton, SWEET
Image Posting Policy
New Reply
Topic Options
#817926 - Thu Jan 19 2012 07:16 PM tie rods
rickyt Offline
Loc: mississauga, ontario, canada
Hi I have 1958 long box. If I go under my truck and grab the bar that runs from 1 tie rod end to the other, I can turn that rod a good half of an inch front and back. Is that normal? Should there be so much play in this rod
Thanks Rick
_________________________
Rick
58 3600 4 on the floor
Top
#817934 - Thu Jan 19 2012 07:30 PM Re: tie rods [Re: rickyt]
Happy Birthday SWEET Online
ODSS Lawman
Loc: Fredericksburg, VA
That depends.
Crawl under the truck and turn the rod again. If the 1/2 of rotation is the end rotating on the ball of the steering arm, that is normal. If it is actually unscrewing then the bolts need tightened after the alignment is correct.
SWEET
Sergeant At Arms
Old Dominion Stovebolt Society
BUNS?!?!?! Where we're going, we don't need no buns.....
1951 Chevy 1/2-Ton
The GreenMachine
Top
#818128 - Fri Jan 20 2012 03:05 PM Re: tie rods [Re: SWEET]
rickyt Offline
The ball stays still but the rod and ends can move forward or back. Nothing is coming unscrewed. I was just worried this bagginess might make the end pop off the ball.
Rick
Rick
Top
#818146 - Fri Jan 20 2012 04:09 PM Re: tie rods [Re: rickyt]
Wrenchbender Ret. Offline
Loc: Lenexa Ks.
That is normal. With the weight off the front axle grab the right front horozontily. Push & pull. If there is any play get someone to do it for you & see if the play is in the tie rod ends. There should be none. Grab the tie rod ends & pull up & down. There should be no play there either. If thats OK then you have nothing to worry about as far as tie rod ends are concerned. Its a good idea to change them over to the new style if you want to work on something & spend some money. Other wise they will be OK.
1956 Chevy 1/2-Ton Pickup
Top
#820568 - Sat Jan 28 2012 03:09 PM Re: tie rods [Re: Wrenchbender Ret.]
rickyt Offline
Thanks guys, did all of the above and everything seems tight. Thanks
Rick
Rick
Top
Moderator:  SWEET
