The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
40 registered (aggie jon, 69Cuda, 55 SHAKER, 29tons, 3 invisible), 468 Guests and 4 Spiders online.
Forum Stats
39,264 Registered Members
48 Forums
104,747 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
58NAPCOGMC, boom construct, buddeal, Cal78, meanmim, RT1
Image Posting Policy
Page 1 of 2 1 2 >
New Reply
Topic Options
#793776 - Sun Oct 30 2011 07:36 PM Speedometer Cable Lube
sleeve Offline
Loc: Northern New Mexico
My speedometer needle jumped all over the place and figuring that my cable was dry or dirty I took it out and while the cable doesn't come out of the sheath I was able to pour WD 40 inside the casing and spin the cable by hand until it turned smoothley then hung it up and let the excess run out.
The question is what weight oil should I use to lube it before I reinstall it ?
Edited by sleeve (Sun Oct 30 2011 07:37 PM)
_________________________
1945 Chevrolet G 506 1.5 Ton Military 4X4
Top
#793782 - Sun Oct 30 2011 07:52 PM Re: Speedometer Cable Lube [Re: sleeve]
Greg_H Offline
Loc: Enid Okla
They actually recommended a powdered graphite dry lubricant.
Top
#793783 - Sun Oct 30 2011 07:58 PM Re: Speedometer Cable Lube [Re: Greg_H]
sleeve Offline
Without being able to get the cable out of the sheath any recommendation on how to get graphite on the entire length of the cable?
Top
#793821 - Sun Oct 30 2011 09:21 PM Re: Speedometer Cable Lube [Re: sleeve]
Achipmunk Offline
Loc: Boiling Springs, S. C. 29316
If you take your time I think gravity will do its job if you put some in the cable and continue to turn it or maybe put some graphite in one end and use a low pressure air hose to blow some down it.....or maybe some light oil, like 3 n 1 would be a carrier to move some on down the line.
Pictures in my Photobucket
Top
#793828 - Sun Oct 30 2011 09:40 PM Re: Speedometer Cable Lube [Re: Achipmunk]
squeeze Offline
Loc: Vancouver Island
do not add powdered graphite now that you've used a liquid on it, unless you get it out and clean it well with a solvent .... why can't you get the cable out of the sheath? should pull out from one end or the other, lube alone won't fix it, the gumbo needs to be cleaned out .... the other choice would be replace it, or possibly the jumpy speedo is as much or more a dirty speedo head
Top
#793860 - Sun Oct 30 2011 11:11 PM Re: Speedometer Cable Lube [Re: squeeze]
1958GMCnut Offline
Loc: Langley BC Canada
use some white lithium grease on the inner cable after cleaning...
GMC: Get More Cash...
1958 GMC
My Webshots photos
Top
#793922 - Mon Oct 31 2011 08:20 AM Re: Speedometer Cable Lube [Re: 1958GMCnut]
Wrenchbender Ret. Offline
Loc: Lenexa Ks.
It should come out through the top. Take it loose at the trans. & straighten out the curve. Pull it out from the top. I have packed them in grease like Cnut says for 60 years & they work from then on out. Put a little oil on the spindle at the end of the speedo.
1956 Chevy 1/2-Ton Pickup
Top
#793924 - Mon Oct 31 2011 08:35 AM Re: Speedometer Cable Lube [Re: 1958GMCnut]
Denny Graham Offline
Loc: Sandwich, IL
Same question comes to mind, that is, why can't you get the cable out of the housing??? I
don't think I've ever seen one that was a sealed unit but I see from your signature that it
might be a military vehicle? That might account for it.
I used to be a real supporter of Lithium grease but having been around long enough to see
what age does to greases I wouldn't use it in anything that wouldn't be cleaned and re-
greased in a couple of years. White greases dry out in a relatively short time compared to
the conventional grease such as chassis or wheel bearing grease. I've taken apart items
that I've used Lithium grease in after 3 or 4 years only to find a dry white caked up
residue left inside. A recent example is a vacuum wiper which was disassembled, cleaned
and reassembled with white grease just a few years ago. Also used it when I rebuilt my
window regulators 4 years ago and there is just some dry residue left on the gears. Who's
product one you say? Radiator Specialties aka; Solder Seal/Gunk Lithium grease and I've
also use some that was packaged in containers for sale by GM parts departments.
A good buddy and I were having a similar conversation a few weeks ago and he said he
used JD Corn Head grease for his wiper motor rebuild. The more I thought about it the
more logical that sounded. It's not subject to cavitation and it's about as light as KY Jelly
or warm Vaseline. And it wonít dry out over time, I doubt if farmer John can spare the
time to clean dried out old grease from his farm machinery every few years.
That said, If it were me and I were able to flush it out with WE40 I'd do like Alvin
mentioned, stand it on end and let gravity do the work with some light 10 weight or 3-in-
One oil. In the past with a conventional speedo cable, Iíve just given the cable a good
rubbing with chassis grease before sliding it back into the housing.
Denny Graham
Sandwich, IL
Top
#793931 - Mon Oct 31 2011 09:00 AM Re: Speedometer Cable Lube [Re: squeeze]
Grant_Bowker Offline
Loc: ottawa, canada
If you want/need to clean out both light lube and any possible older gunk, consider flowing brake cleaner through the cable and sheath by gravity until it comes out the bottom without trace of dirt or lube. You should be able to feel the difference on the cable to know when you've done enough. Also, turning the cable while the fluid works down the assembly will help loosen any remaining dirt or caked lubricant.
Top
#793947 - Mon Oct 31 2011 10:29 AM Re: Speedometer Cable Lube [Re: Grant_Bowker]
Mr. Lang Offline
Loc: Brentwood Bay, BC Canada
I like to mix powered graphite with kerosene or really light oil for this.
Christopher
Pictures in Photodork
1949 GMC Panel Truck
1926 Model TT Truck
Top
Page 1 of 2 1 2 >
Moderator:  cletis
