The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
38 registered (BC59, 55 SHAKER, 1956bs, 53Movinon, 2-Ton, 1951Chevy1Ton, 1 invisible), 600 Guests and 4 Spiders online.
Forum Stats
39,429 Registered Members
48 Forums
105,487 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
ArtBee, doc41, dudeharms, Fahrbach51, fredstev, LaserElvis, Nate b, nate56, SHADEY, skatelonger, toms66
Image Posting Policy
Page 2 of 3 < 1 2 3 >
New Reply
Topic Options
#814731 - Mon Jan 09 2012 02:48 AM Re: Plywood bed-floor for a working truck ? [Re: GMCFreak]
healingbear Offline
Loc: Northern California
Thanks GMCFreak for your post... I recently did my bed in the same material... Hope that it will last 5 years too...
_________________________
In my family for over 50 Years
54 Chevy 3104 3 Window Hydra-Matic Photobucket Pics
54 Chevy 3104 3 Window Hydra-Matic Comcast Pics
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
Top
#815492 - Wed Jan 11 2012 01:16 PM Re: Plywood bed-floor for a working truck ? [Re: healingbear]
magfarm51 Offline
Loc: Kuna, Idaho
For the ones who have gone the plywood route. I have the box off my '51 GMC. Is it easier to install the plywood and cross sills on the box and then install the box on the truck?
Are there any tricks to getting things properly lined up dimension-wise?
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
Here's the most recent one
Synthetic Lubricants
Top
#815628 - Wed Jan 11 2012 09:38 PM Re: Plywood bed-floor for a working truck ? [Re: magfarm51]
healingbear Offline
Allan, I did mine on the frame but not bolted down... I think it might be easier if you had it off the truck... Be prepared to have help putting it back on the frame, it will be heavy...
I measured the bed dimensions... Making sure that the bed was squared when making my measurements... It was a bit difficult for my bed because it has not been together for 20 years... I did not know for sure where the cross stills went in relation to the bed and the frame...
I used two 4 x 8 3/4" sheets of treated plywood... Had them cut where I bought the plywood,( note that lumber stores that have their trim saw inside may not cut them )... The two pieces are the same size so the seam lined up in the middle of the bed, this made it easy to insert the plywood under the welded bed strips... I put a few coats of water seal/stain on them...
The cost for materials was about $ 150... I plan on using it to haul things so I went this route...
Top
#815797 - Thu Jan 12 2012 02:05 PM Re: Plywood bed-floor for a working truck ? [Re: healingbear]
magfarm51 Offline
Loc: Kuna, Idaho
Thanks healingbear. I have the box off but as you mentioned, I'm not sure of the exact locations for the cross sills.
Allan
1951 GMC 1/2-ton
Top
#815805 - Thu Jan 12 2012 02:21 PM Re: Plywood bed-floor for a working truck ? [Re: magfarm51]
healingbear Offline
Allan, if you know the locations of the cross still it would be easier drill in holes for the bolts... I did mine on the truck but had to more the bed side to side and raise the bed to drill the holes... An easier way might be to mark the holes, take the plywood off and drill your holes...This will work if you know the locations of the cross stills... I figured mine out by looking on the frame and saw wear marks and confirmed the front one by asking here on the forum...
Top
#819169 - Mon Jan 23 2012 10:24 PM Re: Plywood bed-floor for a working truck ? [Re: GMCFreak]
mo Offline
Loc: north dakota
why wouldnt you put all the bed strips in. would make it look a little more original. a little time with a router and straight edge and it would look better than original and probably last longer than the original boards with the pressure treated plywood. would let the wood dry outside sitting flat for a month or two first to acamalate to the weather and shrink up. then router and drill, seal everything with a good sealer and install. if done right would look original and nobody would know the difference.
MO's 1951 chevy 3100 resto mod project
Top
#820679 - Sat Jan 28 2012 09:39 PM Re: Plywood bed-floor for a working truck ? [Re: GMCFreak]
cmayna Offline
Loc: Menlo Park, Ca
3/4" ping pong table plywood (which is bigger than the typical 48"x96")does wonders. Cut and rip it to fit your bed. I've had it in my truck for over 20 years of service.
Craig's '50 Chevy 3100 5 window
My truck
If I'm not working on my truck, I'm fishing with the wife or smoking Salmon.
Top
#821345 - Mon Jan 30 2012 07:58 PM Re: Plywood bed-floor for a working truck ? [Re: cmayna]
nrdesieyes Offline
Loc: Santa Cruz, CA
I took cmayna's advice on this and used 3/4" ping pong table plywood as a temporary bed in my '50 -- works great
Top
#824477 - Thu Feb 09 2012 10:10 AM Re: Plywood bed-floor for a working truck ? [Re: nrdesieyes]
magfarm51 Offline
Loc: Kuna, Idaho
I searched and searched for "ping pong table plywood" and couldn't find any, did you guys have to special order it?
Allan
1951 GMC 1/2-ton
Top
#825039 - Sat Feb 11 2012 12:40 AM Re: Plywood bed-floor for a working truck ? [Re: magfarm51]
nrdesieyes Offline
Loc: Santa Cruz, CA
i got mine for free off craigslist. look at the boise craigslist, there's one listed in meridian right now for $5. might be what you're looking for.
Top
